thin, light, cheap, decent keyboard and screen, possible?
Discussion in 'What Notebook Should I Buy?' started by Punchdrunk, Jul 7, 2020.
  1. Punchdrunk
    Punchdrunk Notebook Consultant
    I work in IT support and have a powerful desktop and laptop from work. However the laptop is very heavy and it's keyboard is dying.
    I would like to get a cheap laptop for travelling / sitting on the sofa / my wife to use. It will mostly just be doing web browsing, light office. But it does need to support SSLVPN (openvpn mainly) and remote desktop to windows servers (as my backup device).
    It needs to be thin and light, minimum 13" screen, 14 or 15" even better.
    A lenovo thinkpad x1 carbon would be my dream machine, but is way outside of my price range, and more powerful than I need. I was considering a chrome book, but the good ones are surprisingly expensive.
    Keyboard quality is very important to me. hence the lenovo being my dream machine.
    I'd be happy with a refurbished device if it was significantly cheaper and reduced the cost a lot. I can live with some dings and scratches.
    General Questions
    1) What is your budget? up to £400
    c. Thin and Light; 13" - 14" screen
    3) Which country will you buying this notebook? UK
    a. Like:
    b. Dislike:
    yes
    web browsing, word / excel, remote desktop to windows servers, sslvpn
    travelling quite a bit, or using on lap
    8) Will you be playing games on your notebook? (If so, please state which games or types of games?)
    no
    8+ preferable, but not too important if power supply is light
    willing to buy online, if numerous positive reviews
    11) What OS do you prefer? Windows, Mac OS, Linux, Chrome OS, etc.
    as long as it can do the vpn and remote desktop stuff, any.
    Screen Specifics
    12) What screen resolution(s) would you prefer? (See further below for explanations.)
    13" minimum size, prefer 14 or 15. resolution - full hd.
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (See further below for explanations.)
    not too fussed
    Build Quality and Design
    not at this budget
    Notebook Components
    15) How much hard drive space do you need?
    will keep data in cloud, so not much
    Timing, Warranty and Longevity
    16) When are you buying this laptop?
    soon
    17) How long do you expect to use this laptop?
    would like to get several years of use
    18) How long could you afford to do without your laptop if it were to fail?
    will not be my primary device, I have a powerful desktop and a big heavy laptop
    19) Would you be willing to pay significantly extra for on-site warranty, or would it be acceptable to you to have to ship the laptop to the vendor for repair with perhaps a week or more outage?
    important to keep costs down. ok to ship for repair
    END COPY
  2. Charles P. Jefferies
    A Lenovo ThinkPad E or L series may be more affordable, look into those. I'd also look at the Dell Latitude 14 5000 series and 15 5000 series and the HP ProBook line.
    If they're too expensive then you may need to increase your budget.
    Charles
  3. Punchdrunk
    Ok, thanks I'll have a look at those. Do they have the same quality of keyboard as the X1 carbon?
    What about chromebooks? I've never used one, but on paper they look promising
  4. Charles P. Jefferies
    Chromebooks work if you can do your work through the Chrome web browser, which sounds like it's possible for what you mentioned. Realize they have little local storage and you would need to be connected to the Internet almost constantly to get work done. (Though some apps have offline modes.)
    Also realize that there is a learning curve with Chromebooks - their keyboard layouts are different than Windows PCs, for instance.
    The keyboard feel on all the ThinkPads should be similar. The Dells and HPs I mentioned offer solid typing experiences as well. If keyboard quality is that critical to you, buy from a place that allows returns.
    Charles
