Thin and light powerful laptop
Discussion in 'What Notebook Should I Buy?' started by Serg, Dec 26, 2012.
  1. Serg
    Serg Nowhere - Everywhere
    General Questions
    1) What is your budget?
    Up to $1200, can dish $1300 if really worth it.
    a. Netbook; 10” screen or less
    b. Ultraportable; 11" - 12” screen
    c. Thin and Light; 13" - 14" screen <- I'm tired of carrying with a 15.6" laptop.
    d. Mainstream; 15" - 16" screen
    e. Desktop Replacement; 17"+ screen
    USA, through the Interwebz.
    a. Like: HP, Dell, Sony, ASUS
    b. Dislike: MSI, Acer, Gateway, Fujitsu
    c. Indifferent: Apple, Toshiba, Samsung, Lenovo
    No. Looking for a new laptop.
    Word processing, light 3D modeling, light gaming, heavy web surfing, reading.
    I'd like it to be mobile, yes. Has to be able to withstand traveling.
    Darksiders II
    Dishonored
    EVE Online
    Roller Coaster Tycoon II
    The Sims 3
    Need? 3ish. Want? 5+
    Reviews, pictures and videos should do it. No need to touch it, mostly.
    11) What OS do you prefer? Windows (XP or Vista or Windows 7), Mac OS, Linux, etc.
    Windows 8, preferably. Can get Windows 7 and upgrade. Both 64 bit versions.
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. Click here for Screen resolution information.
    WXGA+ 1600*900 or 900p
    WUXGA FHD if possible.
    13) Do you want a Glossy reflective screen or a Matte/non-glossy screen?
    I'm indifferent to this. Got a glossy one and works well.
    Build Quality and Design
    Hardware and build quality are more important, but it is important that it is somewhat appealing.
    In the next month or two.
    3+ years before I look for a refresh or an update.
    Notebook Components
    500GB is pretty much standard. Prefer it to be 7200RPM at least. Hybrids and SSDs are preferred as long as they're within price range.
    Haven't had an ODD for 3 years, and I've only used the external less than 20 times in those years.
    Basically, the Sony VAIO S 13 Premium is the best option. For $1194.99 I can get an i7-3520, the GT640M LE with 1GB GDDDR3, 12GB of RAM and the 900p screen in a very thin and light laptop. Build quality looks decent enough.
    What else is out there, capable of matching or passing this VAIO S 13 Premium?
    I'm fully aware that NVIDIA mixed with SolidWorks 2012 or CATIA is not the best option ever, but for the light stuff I do, it's OK or capable of handling it (mostly).
    Thank you for your replies and efforts!
  2. RefinedPower
    RefinedPower Notebook Deity
    I would suggest getting the I5 and using the money you save to upgrade the hard drive to an SSD. they are worth every penny of their relatively high cost. If you can pick up a W7 version of the S13p from amazon.com it gives you the option of nearly doubling the clocks on the 640 LE putting it near 650m performance level.
    your other option is to get a Lenovo X230 and then make an eGPU via the express card slot. this would give you the option of using a professional card in the eGPU which will boost your Solidworks performance significantly. the intel GPU performs about the same as the 640 LE with solidworks so you could still work on smaller projects in class and stuff.
  3. Ellatan
    Ellatan Old Timer
  4. Terran1212
    Terran1212 Notebook Consultant
    Acer Timeline U M5 is what I use. It is pretty decent for pretty much everything you have listed except lower screen quality. And it is of course slightly lower build quality than some of the super stuff out there
  5. Serg
    I've looked into the Gigabyte N2442. It looks quite interesting, now I have 2 options, the Gigabyte and the Sony.
    What else should I consider?
