Thermal paste(s), thermal pads and repasting tools for Clevo P650HS?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by thedummy, Apr 16, 2017.
  1. jaug1337
    jaug1337 de_dust2
    Really all the best things have been summed up in this thread.
  2. TANWare
    ICD is the go to for a non conductive. I just redid my laptop with it on installing a i7-3940xm. It takes a few days for the paste to spread and break in but it is well worth it.
    On that note though if you have the fit and poses the Nad's, conductive TIMs are the best you will ever get.
    jaug1337 likes this.
  3. Nneely
    Nneely Notebook Enthusiast
    Im going to be getting a clevo p650hs-g from HIDevolution with the 7700hq. Am I going to be better off with ICdiamond from them or liquid metal?
  4. HTWingNut
    HTWingNut Potato
    @Phoenix
    What was your bad experience? I don't recall reading it here. I have been using it over IC Diamond lately. I like it and so far zero issues.
  5. Ultra Male
    Ultra Male Super Tweaker
    Well I was using LCU at first on my Clevo P870DM and it sucked not because it's bad, but blame it on the flimsy fit of the heatsink. so I solved that by using IC Diamond which is thicker a8nd my max temps @ 4.6 GHz were 88C in a stress test that is, much lower in actual gaming or usage.
    I then heard a lot of good stuff about Grizzly Kryonaut so I bought a tube. It was OK at first, max temps were round 90C but within 3 days, it just started getting worse and worse reaching up to 96C.
    Papusan likes this.
  6. TomJGX
    TomJGX I HATE BGA!
    IC Diamond for me too... Nothing works better lol!
    Papusan likes this.
  7. jaug1337
    jaug1337 de_dust2
    LM on a flat surface :p
  8. TomJGX
    TomJGX I HATE BGA!
    I agree... If you are a noob at repasting and don't want to take risks, ICD is best!
    Sent from my LG-H850 using Tapatalk
  9. Mobius 1
    ic diamond is paste for trash heatsink with large gaps due to crooked surface
    if your surface is flat but don't want conductive, get gelid or kryonaut
  10. Timbabs123
    Timbabs123 Notebook Consultant
    Whats the best thermal pad size? 0.5, 1.0, or 1.5?
    BTW this is for a Clevo P650RS-G Laptop
