Thermal paste recommandations?
Discussion in 'Alienware 18 and M18x' started by nobodyserio, Jul 12, 2019.
  1. nobodyserio
    nobodyserio Notebook Guru
    I finally got my hands on a mxm 1070 from china and a 3940XM.
    Now I just want to ask what would be a recommedned thermal paste for these units.
    IC Diamond was mentioned to work well with the 3940xm, while gelid, noctua and grizzly seem to work well with the gtx 1070, no idea what plates (the ones placed on the sides of the graphic card) to use though.
    Maybe I am overthinking this, but since the m18x disassembly is quite a pain I just want to do it as right as possible on the first try and lock it up tightly.
  2. ssj92
    ssj92 Neutron Star
    IC Diamond should be fine.
    I've heard good things about Gelid & Phobya Nanogrease as well but IC Diamond has performed well for me in these laptops.
  3. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Liquid ultra
  4. Raja786
    Raja786 Notebook Consultant
    I’ve used a few over the years and personally I think IC Diamond 7 works a treat for both CPU & GPU. But any of the above mentioned are good. I’ve heard people regret using LM but some have had no problems. I wouldn’t want to take the risk.
  5. nobodyserio
    thanks to you everyone.
    Liquid metal seems to beat others by one or two celcius, but I do not feel comfortable by messig something up due to teh electric conductivity.
    IC diamond it is then. /? 7 or hatever variant avilable.
  6. M18x-oldie
    Nope, liquid metal easily beats up any other by about 10-15 degrees. I used it on my CPU and the temps went down ~14 degrees.
  7. custom90gt
    I'll disagree with the above, LM has consistently been 2-5C better on the laptops that I've done when compared to Kryonaut. For me it's just not worth the effort on my laptops anymore. I'm all about trying to squeeze every bit of performance out, but I also have to factor in risk vs reward. Undervolting makes a much larger improvement.
  8. M18x-oldie
    Of course there's also always a risk with LM, my system for exapmle doesn't get moved very often and it's always flat on the ground
    Btw, you cannot undervolt every CPU, below Haswell it's not easily possible, as far as I know.
  9. custom90gt
    You're absolutely right about not being able to undervolt older gen CPUs, it's been a long time since I've had my M14x and M17x laptops...
    I don't even really bother with LM on my desktops anymore, just so much easier to use a good thermal paste IMO.
  10. M18x-oldie
    In my case using it really helped me. Went from ~84 C to ~70-72 C, so gained about 12, 13 degrees and could go a +0,2 MHz higher, compared to Gryizzly Kryonaut, which is also one of top spec pastes.
