There seems to be no way to not have a blue keyboard anymore
Discussion in 'Sager and Clevo' started by Boseph McGee, Jul 15, 2019.
  1. Boseph McGee
    Boseph McGee Notebook Enthusiast
    The only reason I kept CCC around was to change up the keyboard lighting now and then, or to turn it off all together. Now with the latest feature update in Windows 10, none of the non-Microsoft store versions of CCC work. Then when I try to load up the LED software that Clevo has on the Microsoft Store, it tells me that my model isn't supported. I have a PA71ES-G. Obsidian's doesn't support my model. Clevo doesn't support my model. Does anyone know a way to just turn off the backlighting completely?
    Thanks!
  2. Meaker@Sager
    Have you reached out to your reseller?
  3. Cypher2019
    Cypher2019 Newbie
    If its anything like the older models the keyboard has 2 connections. The thinner one will be for the backlight. You can unplug that.
