The Wifi Signal Falls When Using a Wireless Mouse. What could be the solution?
Discussion in 'MSI' started by cuneyt1984, Dec 31, 2017.
  1. cuneyt1984
    cuneyt1984 Notebook Consultant
    Hello,I have a GT72VR 6RE.I understand that my problem is related to Trust GXT 130 Mouse. When I use the notebook with this mouse, the wifi signal breaks and decreases. While downloading a file from the Internet, the wifi signal is low while the mouse is connected to the notebook, and the connection breaks.The wifi signal is normal when I remove the mouse receiver from the notebook.
  2. cuneyt1984
    Will not you answer me on this?
  3. Falkentyne
    Falkentyne Notebook Prophet
    Posting a message at 1 AM in the morning Pacific time isn't going to get you much help, especially if you choose to cry for MORE replies at 4 AM. A large part of the traffic here is from the States, and the States were sleeping. And if someone knew the answer to your question, they would have posted. And this issue has been discussed in the past with some Logitech mice.
    Either change USB ports, change mice, try a different wifi card (they are very cheap anyway), change band channels, or even experiment with reversing the Main/Aux antennas and see if that helps.
  4. Spartan@HIDevolution
    get another mouse. problem solved
    Papusan and Falkentyne like this.
  5. cuneyt1984
    Hi, I found the solution. I accessed the channel settings through the modem/router interface. I chose the channel number 8 or 9. All other channels failed.
  6. cuneyt1984
    Also, the most compatible channel for my modem is number 8.
  7. cuneyt1984
    Hi I noticed an interesting situation. When I move the mouse, the WiFi signal is weakening. However, when I stop using the mouse, the modem signal is normal.
  8. Koen
    Koen Notebook Enthusiast
    For optimal wifi neighbourhoods it would be best if people use either channel 1,6, or 11 for 2.4gHz wifi.
  9. cuneyt1984
    I tried these settings. But only wifi works on channel 11. And the same problem continues.
