The ThrottleStop Guide
  1. James D
    James D Notebook Prophet
    unclewebb, Throttlestop has a feature to detect usage on battery and being turned off in that scenario but can I ask why there is no feature as "Load Profile # when on battery"?
    There is a profile called Battery after all so this feature seems intuitive to me.
  2. Vasudev
    Some BIOS might be glitchy when querying battery usage that is why its disabled by default. You can check Options and find battery profile when AC power is unplugged and also Load Profile 'X' when on battery.
    Brad331 and James D like this.
  3. Richard Zheng
    Richard Zheng Notebook Evangelist
    Your results intrigue me! What are your experiences with graphie sheets so far? I got a laptop with uncooled VRMs and was considering using graphite sheets to bridge the heat from VRMs to the heatsink
  4. Brad331
    Brad331 Notebook Enthusiast
    What laptop have you got?
  5. Richard Zheng
    XPS 15. Some people used thermal pads to connect VRMs to the heatsinks, but I am interested to see if graphite pads are a better option
  6. Brad331
    Ah, they're heatsinking to the bottom cover. It's rather tricky to get all those irregular-height components to make good contact. If you slapped graphite sheet on the VRM you'd touch the inductors but not the MOSFETs. I've used an XPS 15 2-in-1 for a bit and the keyboard deck temperatures could be tolerably a lot higher. So if I had an XPS 15 I would definitely do keyboard-side cooling like I did on the MateBook: cover the keyboard backside with graphite sheets and put thermal pads under the motherboard backside. Oh and if there is any GORE insulation I would remove that. But yeah, graphite sheets can spread quite a bit of heat.
    pressing likes this.
  7. Richard Zheng
    They seem to be very flexible, so I could just put it on top of them and keep them pressed in with thermal pads. The main selling point is ridiculously high horizontal heat transfer rate over thermal pads.
    I would keep the insulation, but I think having the graphite sheets would be swell
  8. Brad331
    Cool, looking forward to seeing what you do with them!
  9. Richard Zheng
    I don’t think it will be anything special. Like just a normal repaste results, but with cooler VRMs so it won’t VR throttle. I’ll make a post if I get noteworthy results
  10. Eason
    Eason Notebook Virtuoso
    Only issue with aluminum/heat distribution is that higher distributed heat may mean more failure, as manufacturers tend to cheap out and use other components with lower temperature thresholds than the CPUs are made to withstand.
    Papusan likes this.
