The ThrottleStop Guide
  1. 6.|THE|1|BOSS|.9
    6.|THE|1|BOSS|.9 Notebook Evangelist
    Yes :) this is the effect of HDC but it doesn't effect during idle only.. but also during full load ;) test during load & see if you see difference on power consumption :)
    Vasudev likes this.
  2. THE-HL
    THE-HL Notebook Geek
    Is your dptf fix the reg key one for power options? and should i enabled hdc on a laptop with an i9?
    6.|THE|1|BOSS|.9 likes this.
  3. Greel
    Greel Notebook Evangelist
    where do i find those? im getting both mfc120u and msvcr120 not found, on a fresh install from Xotic PC
  4. 6.|THE|1|BOSS|.9
    Use the one from this post :) here... ✪Low CPU Temp. & High Performance through Intel DPTF Fix✪
    and yes enable HDC.. it is good & harmless & always offer positive results which is lower power consumption,lower temperature, and same or even higher performance ;)
    Maleko48 and c69k like this.
  5. THE-HL
  6. 6.|THE|1|BOSS|.9
  7. THE-HL
    If i have speed shift enabled (set to 80), is it good to uncheck c1e and speedstep?
  8. FrozenLord
    FrozenLord Notebook Consultant
    While I see that DPTF might bring power consumption benefits, my tablet will throttle when using DPTF.
    I am running a Dell Latitude 5290 (2-in-1) which is a Microsoft Surface-style device.
    And it will get quite warm at the back, when I run a power-hungry application.
    This results in DPTF throttling the device via PL1 - it will actively and aggressively reduce PL1 to counter the device's heat output.
    Have you found a way to prevent this?
    The only solution that I found was completely removing DPTF.
  9. Greel
    Maleko48 and 6.|THE|1|BOSS|.9 like this.
  10. ha1o2surfer
    ha1o2surfer Notebook Evangelist
    I tested this but DPTF doesn't seem to do anything on my Dell G7 but instead of deleting the drivers and or blocking them from installing; woudln't it be easier to just disable the service? (for people who want to disable it)
    Maleko48 likes this.
