The ThrottleStop Guide
  1. Falkentyne
    Falkentyne Notebook Prophet
    Did you change uncore offset in your bios?
  2. PredatoR_TR
    PredatoR_TR Notebook Evangelist
    Hello,
    I didnt change anything in my BIOS.
    First I used XTU to find out how much I can undervolt, then changed it to the stock and uninstall it. Then I installed throttlestop and it is what I had. As a stock CPU core and cache were +20, and Analog I/O was +125
    Laptop is Asus G703VI
  3. unclewebb
    unclewebb ThrottleStop Author
    On a stock CPU, all 3 of those settings are zero. Either your bios set those or Intel XTU did. I would have a look in the Task Manager and make sure that there are no Intel XTU remnants still running in the background. Do a full shutdown, not a hybrid shutdown. Before running ThrottleStop, delete the ThrottleStop.INI config file. When ThrottleStop starts, it will create a new config file and for default values, it will use whatever your CPU is set to. A positive offset for core and cache is not a good sign. Not sure why a bios would use settings like that. Intel CPUs never need more than default voltage. They always need less. That is why under volting is popular.
    Vasudev, PredatoR_TR and Papusan like this.
  4. PredatoR_TR
    Hi,
    Thank you for the answer.
    I set ''standard'' instead of ''extreme'' at ROG Gaming Center and uninstalled it. Then I installed XTU and interestingly first thing I saw there was +20 CPU voltage offset. I didn't know about Analog I/O. Anyway, I made ''default'' settings with XTU and unistalled it. I was very surprised with +125 Analog I/O. Can I check somehow original figures from BIOS If I somehow changed it?
  5. Papusan
    Papusan JOKEBOOKS = That sucks! Dont wast your $ on FILTHY
    With almost locked down bios, Nope. I would uninstall the Asus software and clear NVRAM. Maybe put bios default first. And start clean. Then fire up TS and see what default settings will be showed.
  6. PredatoR_TR
    What do you mean with Asus Software? Rog Gaming Center? It is already uninstalled in the beginning. If I format my laptop, I think I will get original figures, right?
    One thing to mention, only thing I did at BIOS is updating it.
    If I will see these +20 cpu offset voltage, and analog i/o +125, should I worry? Do you think that it will cause problem for me?
    FYI, currently my laptop works -105mv cpu offset voltage and analog i/o is set as 0.
  7. Papusan
    Yeah, I expect Rog Gaming center also contain Asus own overclocking tool(settings for Cpu). Or have Asus other tool for this?
    The reason I said clear NVRAM/ put default in bios... Could be that XTU has screwed up bios settings.
    Default bios settings should show exactly “default Cpu voltage” settings or Asus engineers have done something nasty in their firmware. I don’t know, I don’t have this laptop.
    raz8020 likes this.
  8. PredatoR_TR
    So cleaning NVRAM will put BIOS default. Sorry, it is not easy to understand for me always. :) I would say only Asus software can screw things up.
  9. Papusan
    Bad settings can be stored in NVRAM. Put bios to default doesn’t always help. Google how to do it for your particular notebook. Try put default settings in bios and see how it goes first. Then run ThrottleStop again(delete TS ini file first in TS folder for starting on scratch). Do this before you fiddle with bios settings. Then read what Cpu settings TS will show once you start it.
    Edit.
    I post from my phone so maybe @Falkentyne or other can explain better if you still don’t understand.
    raz8020 likes this.
  10. noequal_1
    noequal_1 Newbie
    ok, i'm relatively new to the whole Throttlestop schtick, but, undervolting seems pretty self-explanatory and getting lower temps on my laptop sounds excellent. so, after i undervolt and make sure the computer it stable, i hit ok and everything seems fine. it seemed to work perfectly, but... my question is, after i end up restarting my pc and don't have Throttlestop starting automatically, how can i tell if the undervolting is still being applied? i have Turn On in the bottom left of the main window selected, so, I'd hazard a guess that its working, correct? i'm just unsure. i just wanna make sure this is still working.
