The ThrottleStop Guide
  1. GTMoraes
    GTMoraes Notebook Consultant
    Thoughts, only?
    It seems to be losing the Bus clock for some reason. Maybe your board isn't refreshing it correctly, or throttlestop is having a very weird time retrieving it.
    Shouldn't do any harm. Just consider the first number and multiply it by 100 (which is probably your Bus clock) e.g. 31.75 x 100 = 3175MHz, ~3.2GHz
    I just found out that by changing the white box with a 0 in the "TDP Level Control" line, on TPL window, to 2, boosts my minimum TDP before throttling from 15W to 25W, which is precisely what I needed!
    And it sticks after rebooting, sleeping and removing the charger, unlike XTU.
    Love this program.
    pressing and Vasudev like this.
  2. GreatD
    GreatD Notebook Consultant
    Hey All and sir @unclewebb. Apologies in advance of this has been asked before. Is it completely safe for TS to run continuously even if one isnt stressing the their laptop/pc out? I read that the VRM's (above the CPU- small black chips- there are 5) take strain, get super hot and work much harder when the CPU is undervolted? Is this a Myth or is it true? Should I be worried. VRM's are very sensitive to heat etc.? Please inform me. Much appreciated and great work on TS. Screenshot_20180615-065530_Gallery.jpg
  3. GTMoraes
    Che0063 has answered that already:
    31336, raz8020, Vasudev and 1 other person like this.
  4. GreatD
    Thank you so much :) I'll continue to keep undervolting on even on idle
  5. captn.ko
    captn.ko Notebook Evangelist
    Hi :) Thanks for this awesome app @unclewebb :) Iam using it for a while now with my i98950HK. I have only 1 Problem. When using Throttlestop my Speakers make strange (noisy) noise when playing Audio sounds. Is there any solution?
    Vasudev likes this.
  6. Falkentyne
    Falkentyne Notebook Prophet
    Is that a CONCAVE CPU staring me in the eye there?
    Since when are CPU cores CONCAVE?
  7. captn.ko
    Or the lamp above could be....circular?
  8. Falkentyne
    Or could be both?
    I saw an alienware setup that was shown with a (square/flat lamp, and the same curve (same exact curve) appeared on the CPU at the edges.
    Was a thread way back on the Alienware temp differential 6820hk thread. So I stand by convex.
    Vasudev likes this.
  9. Papusan
    Yeah, All silicon is convex, more like a pyramid. Of course Intel BGA is equal. They are just lower binned chips.
    Vasudev likes this.
  10. captn.ko
    Found the Problem... dont touch the min cache clock with Throttlestop. If you do you get sound latency from hell...
