The ThrottleStop Guide
  1. Vasudev
    Vasudev Notebook Prophet
    Thanks. Did you update the BIOS to latest one available as of now?
  2. Beempje
    Beempje Notebook Enthusiast
    I did. Just checked if I'm on the latest version, which I am (did a BIOS update last week).
  3. Vasudev
    So, uncheck BD PROCHOT option in TS and play that game again and see if it fixes issues like strange stutters or throttling.
  4. Beempje
    Thanks for the suggestion. Actually my default profile (and the one I had running when the crashes occurred) already had BD PROCHOT unchecked. Also, it wasn't stutters or throttling, it was a total system freeze out of nowhere, with the game running like a dream just the second before...
    Vasudev likes this.
  5. Falkentyne
    Falkentyne Notebook Virtuoso
    You're undervolting right?
    If the CPU is only using 11-12W, it means that there is almost no CPU power load, and thus the CPU is downclocking. If you are using ADAPTIVE VCORE, it means that the adaptive voltage is also being set lower. If you are undervolting, then the undervolt applies to BOTH the idle voltage and the load voltage. It's possible that at (low load) idle one of the voltage steps is unstable because of the undervolt. The way to fix this is to reduce the undervolt by a little bit.
    This is one of the problems with dynamic voltages. You can see the same thing happen with Pascal video cards. Set a certain overclock when NOT locking the voltage (if the voltage is locked with control L on a point, the vcore will only be reduced when hitting power limits or the temperature throttle -13 mhz steps), the card might be stable for hours at full load and higher heat, but when first starting a game, it may crash in the first minute, as the temps are low and the voltage hits a certain voltage step which winds up being unstable at that core clock.
    The "on/off" button only controls the power saving options in the main window (Speedstep, C1E). Not the profiles or monitoring.
    Vasudev likes this.
  6. Beempje
    Thanks for your reply! Yes, I am undervolting and your reply sounds plausible. I'll have to try it out later tonight. I'm pretty sure that I tested with a neutral normal volted profile too and saw the same results (crash), but I'll double check that too.
    I'll report back when I know more. Thanks for the replies so far! :)
    Vasudev likes this.
  7. Beempje
    Okay so I tested some more. Changed the game profile so there's no undervolt happening, made sure BD PROCHOT is unchecked. Yet the same behaviour occurs: a couple seconds after the fan kicks into high speed, the whole machine crashes and reboots. See the screenshots below for the settings I used, and the last couple of lines from the log right before it crashed.
    Code:
       DATE       TIME    MULTI   C0%   CKMOD  CHIPM   BAT_mW  TEMP  GPU     VID   POWER
    2017-10-11  21:00:51  27.51   21.4  100.0  100.0        0   68    63   0.9310   11.4
    2017-10-11  21:00:52  28.47   21.5  100.0  100.0        0   63    63   0.9349   11.9
    2017-10-11  21:00:53  27.94   20.9  100.0  100.0        0   65    63   0.9296   11.3
    2017-10-11  21:00:54  27.70   21.8  100.0  100.0        0   64    63   0.9143   11.6
    2017-10-11  21:00:55  27.57   21.3  100.0  100.0        0   68    63   0.9158   11.1
    2017-10-11  21:00:56  27.74   21.7  100.0  100.0        0   68    63   0.9523   11.6
    2017-10-11  21:00:57  27.50   22.0  100.0  100.0        0   67    64   0.9578   11.5
    2017-10-11  21:00:58  28.01   21.8  100.0  100.0        0   65    64   0.8909   11.5
    2017-10-11  21:00:59  27.41   21.7  100.0  100.0        0   67    64   0.9009   11.3
    2017-10-11  21:01:00  27.54   21.6  100.0  100.0        0   67    63   0.8856   11.4
    Any ideas? :)
    Vasudev likes this.
  8. Beempje
    Looking at my own reply I see the CPU cache is still undervolted, even though it says in my settings it isn't.... I'll see if I can reset it and if that changes things.
  9. Vasudev
    Never undervolt iGPU. Any monitoring apps like HWINFO or HWMON running in background? Disable any Dell Command Center or similar.
  10. Beempje
    Thank you! Apparently the Dell Performance Optimizer was running in the background. I had no idea it existed, but there you go. The DPO and ThrottleStop were (probably) getting into a fight, resulting in the crashes. You live and learn :)
    Also, the undervolt on the game profile is a no-go apparently. Or at least not as much as I had it on. I tried setting the undervolt back while the game was running and it crashed instantly :p
    Thanks a bunch for the help guys! Sorry for asking newbie questions, it's a complicated piece of software but I'm starting to get the hang of it.
    Btw Vasudev, you said never to undervolt de iGPU. Can I ask why?
