The ThrottleStop Guide
  1. zainsy
    zainsy Newbie
    so guys
    core i5 4200U
    undervolted cash and cpu to 50mv
    gpu 70 mv
    gpu2cpu 7 ( i have dedicated amd gpu so i don't need intel igpu in gaming)
    playing cs go and in 15 minutes power limit throttle kicks in
    the package tdp is under 15 W
    why da hell does this happen any tips?
  2. alexhawker
    alexhawker Spent Gladiator
    Because it's an ultra low voltage chip.
    unclewebb likes this.
  3. zainsy
    zainsy Newbie
    is there a way to jump over this limitation ?
  4. keshavmot2
    keshavmot2 Notebook Enthusiast
    @unclewebb
    Is it possible to extract the winring0.dll driver from Open Hardware Monitor and put it in the Throttlestop folder so I don't have to run OHM on the Insider builds to open TS?
    Thanks for all of your hard work!
  5. ajc9988
    @unclewebb - any chance this can be used for something like Ryzen or TR, or do you have a recommendation for looking for throttling on those platforms?
  6. unclewebb
    unclewebb ThrottleStop Author
    @HTWingNut - In the TPL window, try enabling and adjusting the Intel Power Balance feature so the Intel GPU gets more of the power budget than the Intel CPU. I have had zero hands on time with an Atom x7-Z8750 so I am not sure what is possible.
    Some manufacturers force their U CPUs to go into cTDP down mode so the TDP power limit will drop down to 10 Watts or maybe only 7.5 Watts. A lot of times this is totally unnecessary but they do it anyhow and there is nothing a user can do about this. It is too late for you but my recommendation for others is if you buy a low power U CPU, run it into the ground day one and if it is not fit for your purpose, take it back immediately. I was getting 28 Watts out of my wife's U CPU so a low power U does not have to be a miserable experience. It all depends on the individual manufacturer. A U CPU can be brutally sluggish and close to unusable for anything beyond surfing the net or it can run like this 7500U. Definitely no complaints here.
    @keshavmot2 - Open Hardware Monitor has wrapped the WinRing0 driver within their OpenHardwareMonitorLib.dll
    Windows 10 Build 16273 does not like the WInRing0 driver that ThrottleStop is using so switching over to the OpenHardwareMonitorLib.dll is a possibility but a month from now, Microsoft might decide that they do not like the Open Hardware Monitor driver either and will block that too. I have got a feeling that Microsoft really does not want individual programmers like myself being able to control CPU voltages, etc. Their friends at Intel have probably been twisting their arm for years about this security risk so MS is finally cracking down.
    At the moment, I do not plan to do anything about this problem. I really do not need the new Emoji Bot or the new Bahnschrift font that Build 16273 brings to the table so I am in no hurry to upgrade to this.
    @psyke83 - Thanks for finding the Open Hardware Monitor trick.
    I am sure Microsoft appreciates your work as much as Intel appreciates my work. :D
    @ajc9988 - ThrottleStop will never support Ryzen CPUs.
  7. keshavmot2
    If there is a possibility to fix it, at least for the time being, we would really appreciate it as this will affect all users who update even in the normal ring soon enough.
    I really appreciate all of your hard work, and if you can't do it, I totally understand. If there is a way I could replace the driver myself or something, I am willing to do that also if guided.
  8. plee82
    plee82 Notebook Evangelist
    How is XTU getting away with this then? There is nothing safe in XTU compared to TS. Freaking control freaks.
  9. unclewebb
    @keshavmot2 - There is no possibility that this is going to be fixed anytime soon. Using the Open Hardware Monitor driver is one possibility but I would be required to release all source code for ThrottleStop as open source which I am not willing to do at the moment.
    Intel's pockets are quite a bit deeper than my pockets. They can afford their own drivers. This is all about squeezing individual developers out of the picture in the name of improving security. If I wasn't the one being squeezed out, I would be all for improved security.
    duttyend likes this.
  10. mbze430
    mbze430 Notebook Enthusiast
    any known issues with Throttlestop with Windows 10 16278.rs3? Keep getting error message can't load WinRing0.dll since the last Fast Ring update
