The ThrottleStop Guide
  1. Falkentyne
    Falkentyne Notebook Virtuoso
    leftsenseless likes this.
  2. syncd
    syncd Newbie
    @unclewebb Thank you very much for your help.
    I see your point regarding disabling BD_PROCHOT, and i would just leave at that, but unfortunately that only solves half the problem because sometimes the laptop keeps on beeping (like right now...). Disabling BD_PROCHOT fixes the throttling but it can't do anything about the stupid beeps...
    I believe it has something to do with the fans but I can't check it right now.
    Any way, I've followed your suggestions and disabled BD_PROCHOT and enabled SpeedShift (why the hell do vendors disable this by default?). Haven't touched the Clamp option because I don't fully understand what it does, but i'm sure it is answered somewhere on this thread so i'll keep looking.
    I've enabled logs and captured an instance of the issue occurring: https://pastebin.com/5CuT9M9q
    Not sure if something can be conclude by it, I see the processor getting throttled (when the multiplier goes to 4) but not much else. By the way, this was triggered by opening a browser with 10 tabs or so opened, so even though the cpu goes to 100% and the power to 13W-14W it's really not much load. When the multipliers goes back up it's me disabling BD_PROCHOT on Throttle Stop.
    Guess i'll have to open it up and check the fans. If I can't figure it out i'll have to send it back to China which I was trying to avoid.
    Anyway, thanks for your help (and for Throttle Stop).
  3. methyn
    methyn Notebook Enthusiast
    Hi unclewebb,
    I have been using throttlestop form earlier versions and this is my favorite software. It is working great with my Lenovo y50 that likes to throttle. I have a problem with the new version of the throttlestop 8.4.8.0.
    Previous versions I can set my cpu to 3.2 ghz but with the obsidian my cpu returns to its stock values and throttle to 2.6ghz. I have tried disabling/enabling BD Prochot anc cant fix the problem cpu temperatures are fine.
    The previous versions works just fine. What am I doing wrong? Please help.
      File size:
      29.7 KB
      49
      File size:
      54.8 KB
      47
      File size:
      752.9 KB
      51
  4. Falkentyne
    Did you check limit reasons?
    Did you try checking the overclock box in fivr?
  5. Eason
    Eason Notebook Deity
    methyn and alexhawker like this.
  6. methyn
    Yes, I have checked/unchecked overclock setting but that doesnt work... :vbfrown:
  7. Vasudev
    Vasudev Notebook Prophet
    In newer builds Windows Creators Fall Update, power throttling will be present, then we can never know for certain if a app is throttled by high temps or the OS itself. This happens on battery, I assume and not on AC.
    methyn likes this.
  8. Miguel Pereira
    Miguel Pereira Notebook Consultant
    If you have a recent version I can pay to have it not expring, i'm the first to jump in. ;)
    Is there a easy way for the most recent version to auto-start on windows 10? I thought I read about it from the obsidian guy somewhere, but I cant seem to find a direct option for that on windows 10. Its just a minor detail, I can always just start the program myself, but if there an easy way I'm all ears.
  9. Falkentyne
    @Miguel Pereira I already beat you to that, several posts ago. (i swear everyone ignores everything I post unless they need something...)
    But @unclewebb hasn't been online since :(
  10. methyn
    It is throttling on AC too. I have no luck with y50. :(
