The ThrottleStop Guide
  1. Vasudev
    Vasudev Notebook Virtuoso
    I tried Powercut feature on Lenovo g50-80 with i5 5200u with TDP=15W and still hits TDP limit. It just peaks to 13W even on wprime 32m[ 4T=18secs 8T=17secs] with cpu temps 55-56C.
  2. Jdpurvis
    Jdpurvis Notebook Consultant
    You don't have the details of your laptop in your signature, so I cannot tell if you have a separate GPU. It is common for a laptop with a QHD screen to have two GPU's - the Intel one on the processor, and a separate, discrete (often Nvidia) GPU. Most are set up to default to the intel GPU for most things. - however, an application that is sending QHD info to the display will stress the processor and the underpowered Intel GPU simultaneously. If you do have an Nvidia processor, you can set the driver to use that processor for HD video applications and games. Good luck, Joe
    Vasudev likes this.
  3. unclewebb
    unclewebb ThrottleStop Author
    No. It was the Lenovo E570. It has the Core i7-7500U, an Nvidia GTX 950M and I added a Samsung 960 EVO M.2 drive. Not a bad little laptop after you do you some undervolting and a few other minor tweaks to it. If Lenovo did the tweaks before shipping it and offered some improved screen options, they could sell a pile of them. I think I was at default voltage when it was running LinX at 28 Watts. I was trying to make it throttle but it was being a real trooper. With a -100 mV undervolt, it dropped to about 22 Watts. Any normal load was a lot less than that.
    Probably but no one here knows the answer to your question. If you bought me a 1000 Acer laptops of the exact same model and I tested them using ThrottleStop for a few years, I could see how many failed and give you a better answer.
    All I know is that for more than 6 years, thousands of people have used ThrottleStop to help fix their throttling laptops and there have been virtually zero complaints about laptop failure due to using ThrottleStop. If I owned your laptop I would disable BD PROCHOT but it is your laptop so you have to take responsibility for it.
    Just remember that most gaming laptops are not designed to be used for gaming while running on battery power. Very few laptops have batteries that will allow an Intel 4 core CPU and Nvidia GPU to both run at their full rated speed while running on battery power. Using ThrottleStop to try and force this to happen while on battery power could permanently damage your battery or possibly cause a battery fire. That would not be good so use some common sense when using ThrottleStop.
  4. Falkentyne
    Falkentyne Notebook Deity
    Throttlestop can't force a dedicated GPU to run at full power anyway on battery. The dedicated GPU gets spammed with "Temperature Limit" (even at 40C) and "Power limit" and VREL limits and capped.
    Not sure about CPU.
  5. Gilang Luqman
    Gilang Luqman Notebook Enthusiast
    my x9100 already come and installed on my laptop (using BSEL mod)
    It can boot up... :cool:
    max multiplier is 18 (3.6 Ghz) in 1.2875V , its stable in prime95
    It will BSOD when I try to increase voltage to 1.3V++ so its not possibly to get 4 Ghz :(
    my laptop multiplier only reach 6 when laptop adaptor unplugged
    I have a question, Can I make it multiplier stay at 18 althought laptop adaptor unplugged?
    here the pic of my problem
  6. Vivekananda
    Vivekananda Newbie
    [/QUOTE]Probably but no one here knows the answer to your question. If you bought me a 1000 Acer laptops of the exact same model and I tested them using ThrottleStop for a few years, I could see how many failed and give you a better answer.
    Just remember that most gaming laptops are not designed to be used for gaming while running on battery power. Very few laptops have batteries that will allow an Intel 4 core CPU and Nvidia GPU to both run at their full rated speed while running on battery power. Using ThrottleStop to try and force this to happen while on battery power could permanently damage your battery or possibly cause a battery fire. That would not be good so use some common sense when using ThrottleStop.[/QUOTE]
    Thank you for answer. My english is very poor. I not play games at all. Just run throttlestop when battery low (under 40%) and procesor is then slow about 800mhz. And then I work some ushual things, photoshop, internet and so on... I ask you can I run throttlestop all the time (not playing games, just for regular things) when in AC also, not just on battery?
    I asked just becouse warning at start of program.
    Thank you in advance
    Also get a error follow your insttions to put throttlestop in start programs (win 10)... I try many times, step by step and allways got some kind of error.
    Vasudev likes this.
  7. Vasudev
    You can pin TS to start menu and after startup simply click on the icon to get it started, that's what I do.
    Vivekananda likes this.
  8. Vivekananda
    Vivekananda Newbie
    Thanks, I allready do that, but wandering why can't set it in start menu.
  9. Vasudev
    If you have W8 or W10, you pin it to Start. On Win 7 you can pin it to taskbar.
  10. bruor
    bruor Notebook Consultant
    To get throttlestop to start automatically I added a task scheduler entry to launch it at logon.
    Sent from my Nexus 6P using Tapatalk
