The ThrottleStop Guide
  1. Ec1ps3
    Ec1ps3 Newbie
    Hey im sorry if this was asked and answered already, but how do I get ThrottleStop to only Show as Icon in the System tray? I set a Task to run it at Login nbut id like to have it not showing up on the dock at all and only run in the Background in the tray. How do I do this?
  2. boricuafly
    boricuafly Notebook Consultant
    No problems whatsoever with the new version!
    Thanks!
  3. Ec1ps3
    Ec1ps3 Newbie
    H im stupid, I found it! Was always looking at the Options :confused:
  4. e270889o
    e270889o Newbie
    Happend to me a lot. For example, its impossible to play Battlefield 1 WITH DX12 and throttlestop. If i try it, as soon as BF start loading, TS comes into first place. Anyway, DX12 sucks with my 860m
    for your info,
    4710HQ, nvidia 860m optimus
  5. asuslaptopfan
    asuslaptopfan Notebook Enthusiast
    Omg, I have this problem of TS 8.30 popping up all the time when gaming. So much to the extent, I can't use my gaming laptop for gaming anymore without turning off TS. Can I have the new test version to see if it resolves my pop up issue?
  6. Gofspar
    Gofspar Notebook Consultant
    I'm having and issue with my TS not wanting to close into my system tray, instead it just sits in my taskbar and refuses to go into the system tray.
    Is this a common issue with the newest ver, or am I just stupid?
  7. Spartan
    Spartan Notebook Nobel Laureate
    @boricuafly also reported this, I think the new Beta 8.35 fixes that
  8. unclewebb
    unclewebb ThrottleStop Author
    Is Task Bar checked? If Task Bar is checked, ThrottleStop should minimize to the task bar. If Task Bar is not checked, ThrottleStop should minimize only to the System Tray / Notification Area which is usually at the lower right. If you are still having problems, try cleaning your icon cache.
    http://www.digitalcitizen.life/how-clean-notification-area-icon-cache
    Next version with a few bug fixes should be ready in a few days.
    duttyend and Spartan like this.
  9. wkamil
    wkamil Notebook Consultant
    I've tested v 8.35. No popup issue at all (v 8.30 was also good for me).
    Spartan and unclewebb like this.
  10. tusctodd
    tusctodd Notebook Enthusiast
    I can confirm that I also have the issue with Throttlestop 8.3 popping up when fullscreen gaming.
    2 different laptops, same issue.
    Thank you
