The ThrottleStop Guide
  1. tgipier
    tgipier Notebook Deity
    Just realize, when gaming on battery, the battery may not be designed to handle a massive 300w+ draw and may need to throttle the components.
  2. zamoeba
    zamoeba Notebook Enthusiast
    I've been at this for days.
    I have a clevo with a 980m and 4720HQ.
    Just about any time my GPU has any reasonable load, the CPU throttles itself (disables turbo?) and the EDP buttons flare red despite humble temperatures, even if I'm barely using the CPU. I have tried raising amp limit in bios, in throttlestop, I even bought a 330W power supply. And about every other bios and throttlestop setting that seems related to power management. I think Unclewebb somehow solved this issue on his laptop but can't quite figure out how.
    Assuming no one has any ideas, does anyone know if there's a GPU equivalent of Dufus' powercut? Seems that throttling is a function of GPU so tricking the computer into believing GPU draw is lower might work.
  3. unclewebb
    unclewebb ThrottleStop Author
    @zamoeba - As always, can you post a screenshot of how you have ThrottleStop setup? Have you tried using the PowerCut feature in ThrottleStop?
    There is a duplicate current limit in the CPU that ThrottleStop does not have access to. If this variable is not locked by the bios, you might be able to use RW Everything to change it. The throttling problem you have is different than the throttling problem in my Y510P. My Y510P disables Turbo Boost but it does not set off EDP in Limit Reasons.
  4. zamoeba
    Here's a screenshot of my current settings.
    Why does my CPU wattage increase when I lower VCCIN (no powercut)? Is it because it measures the relative voltage to the regulator so it perceives it as higher?
    Powercut seems to correctly obscure my CPU TDP but it doesn't seem to do anything other than that.
    If I run furmark, my cpu throttles to about 2.7ghz and voltage ID drops to about 0.8. And furmark is very weak on CPU usage.
    If I undervolt my CPU by 50mv or so, then it throttles to 2.9ghz, however that's still a very noticeable throttle and I "feel" like there must be a better way.
    I noticed a few other posters' GPU throttling their CPU but have not come across explicitly how they solved it.
    You have put a lot of effort and work into this. And continue to help people all this time. Not really thanking you (though there is that) I guess I just admire it.
  5. Samot
    Samot Notebook Evangelist
  6. 00riddler
    00riddler Newbie
    At least on a Desktop I7-6700k setting the multiplier is working.
    ole!!! likes this.
  7. Jafaro
    Jafaro Notebook Enthusiast
    Thanks for the program!
    unclewebb likes this.
  8. ole!!!
    ole!!! Notebook Prophet
    @unclewebb when you do implement the left/right click in next beta, is it also possible to have more than 4 profiles lol. i find 4 isnt enough haha.
  9. unclewebb
    @unityole - I have to be honest, a few more profiles has been on my mind. I typically only use one profile but I will keep thinking about this idea.
    Papusan and ole!!! like this.
  10. Spartan@HIDevolution
    IMO I think 2 -3 profiles is best. Too much and it gets messy with diff. settings to manage for each profile. Just my 2 cents. To each his own
    I use one for high performance / benchmarking, 1 for gaming, and one for normal use / internet browsing
    TomJGX likes this.
