The ThrottleStop Guide
  1. Shnxxx
    Shnxxx Notebook Enthusiast
    I was surprised too and left confused why does XTU behave like that.
    Is there any way to overcome this? Because I'm wondering if ThrottleStop/XTU could somehow configure some CPU settings, why it can't bypass the manufacturer's configurations? Which I think doing the same approach? I'm not an expert, I'm just saying what I think is logical.
    I did a clean reset of my laptop last November and all manufacturer's pre-installed software and services were all gone.
    I did try researching it and I saw a lot of forums saying to disable it too. I found one that could be seen under Power Options but unfortunately, I don't have any kind of option like this. The other one has two methods: configuring Registry or Group Policy. Here's the link of the second one: Easily Disable Intel DPTF (I was carried away on how he modded his laptop)
    I am not aware that there was a thing like that back then. I just bought it because of its price and it's great specs back then in 2018. It was the best laptop I could find at 300$.
    I just did it and after running Cinebench R15, I only peaked at 2.5GHz at 57°C
    That's awesome. I hope I could make it too.
  2. Shnxxx
    So after running some Cinebench R15 and trying all the suggested configurations, here are the reports of ThrottleStops:
    TS Menu
    Limits
  3. Papusan
    What CBR-15 Score you got?
    This is the minimum you should expect
    And did you remove the clamp and put in 44 ?
  4. Shnxxx
    I got 553cb only
    I can't remove it. I experimented a little and checked the "Lock" thinking that I can uncheck it if it doesn't change anything. Is there a way to reset it? I tried deleting the ".inf" but didn't work.
  5. Papusan
    You deleted the TS ini file in TS folder? See... Close TS then delete TS ini file in the TS folder. Restart machine and start on scratch again.
    tilleroftheearth likes this.
  6. Shnxxx
    Yes, it was ".ini" not ".inf" my bad.
    After the restart, I've started from scratch again and this is what I've done:
    TS MEnu:
    Cleared BD PROCHOT
    Checked High-performance
    FIVR:
    Set CPU Core and Cache voltages to -85.0mV
    Checked "Disable and Lock Turbo Power Limits"
    Clicked Apply and OK
    TPL:
    Changed "Turbo Boost Long Power Max" to 44 and unchecked "Clamp"
    "TDP Level Control" is grayed out but it was configured as unchecked and set to 2
    Intel CPU and GPU were changed, I forgot the old values but it is changed now to 11 and 12, respectively.
    TS Menu:
    Clicked "Turn On" and "Save"
    Ran Cinebench R15 3 times and my last score is 524
  7. Papusan
    Max out IccMax. Try also run CBR-15 with TS disabled. Aka restart without TS start up to see default results.
    Proper working 8250U... With similar TS settings
  8. Shnxxx
    TS Off:
    527cb, 2.57GHz @ 64°C
    TS On (Maxed out IccMax both Core and Cache):
    543, 2.72GHz @ 66°C
    Doesn't even reach 3.4GHz. It could only reach 3.4GHz when not stress testing or idle, which very weird. When I needed 3.4GHz it doesn't give it to me, and when it is not needed, it runs 3.4 constantly...
    Also it is running 3.4GHz @ 4W only. But with Cinebench it runs 2.7GHz @ 18.7W
    I just noticed that my Core VID is 100mV higher than yours.
  9. Papusan
    You could try out -100mv to squeeze out more performance within the power limits but this won't fix the machine to work properly.
    This for all buyers of notebooks. As a reminder how bad it can be.
    How Dell cripple performance explained by.....
  10. Shnxxx
    What's even makes me more confused is that at idle it is running @ 3.4GHz with 4W only, while using Cinebench it runs @ 2.7GHz with 19W...
    I'll try right away changing to -100mV
    I would like also to ask, what are these?
    I couldn't find any explanation from these settings.
