The ThrottleStop Guide
  1. unclewebb
    unclewebb ThrottleStop Author
    @GooPuddles - Scroll to the top of this page, enter mfc120u.dll into the Search... box at the top right, check the option, Search this thread only and then click on the orange Search button.
    It only took me a few seconds to find a relevant post by @Kers
    http://forum.notebookreview.com/threads/the-throttlestop-guide.531329/page-969#post-10856200
    Edit - I entered mfc120u.dll and ThrottleStop into Google. It was even quicker finding the info this way. Maybe this is a test to see if you should be using this program or not. :p
    tilleroftheearth and Papusan like this.
  2. GooPuddles
    GooPuddles Newbie
    I probably shouldn't! I just bought a laptop and read that this is a program to make sure the new laptop's thermals are okay. I'm certainly not going to overclock.
  3. Papusan
    You still need to know how to use it... The ThrottleStop Undervolting Guide (2019)
    Ashtrix, Vasudev and tilleroftheearth like this.
  4. Vasudev
    @unclewebb I tested new uCode for Skylake D6 and TS 8.72 and performance seems to have improved for highly threaded tasks. I'm just seeing 0.3ms hit in TS bench as opposed to D4 uCode which had 0.8ms difference compared to CC uCode.
    And good news is, undervolt is working w/o any issues. But, I think 125mV undervolt is the max now.
    Papusan and unclewebb like this.
  5. Avé César
    Avé César Notebook Consultant
    With or without the intel patch for plundervolt or mcupdate_GenuineIntel.dll via windows update please ?
  6. Krzyslaw
    Krzyslaw Notebook Consultant
    I am not an expert but I think that UV might works because ucode from mobo bios is loaded first and after that you are loading newer ucode via vmware software?
    I think that when you insert nawet ucode directly into bios UV wont work if this ucode is a patch for plundervolt
    Vasudev likes this.
  7. unclewebb
    Hopefully someone with an HP laptop that no longer allows under volting will show us what microcode version his laptop is using.
    Then we can try to check whether this was from a recent bios update or a Windows microcode update with a new mcupdate_GenuineIntel.dll
    Vasudev, Papusan and tilleroftheearth like this.
  8. SnakeSK
    SnakeSK Notebook Enthusiast
    Xeon E2186
    WinUpdate shows 0xB4, 0xBA comes from latest UEFI firmware then
    unclewebb likes this.
  9. unclewebb
    @SnakeSK - Did you manually update your UEFI Firmware or did your laptop come pre-installed with this version? It is also possible that your laptop comes with software that took care of the UEFI Firmware update for you. It might have happened in the background and you barely noticed. Thanks for sharing your microcode version.
  10. SnakeSK
    I always update my UEFI firmware (company policy and also dogfooding, before any public release :) ).
    And yes, capsule update is already on the Windows Update, so this particular firmware is already being deployed with no option of rollback (this is so called fixed version release)
    Vasudev and unclewebb like this.
