The ThrottleStop Guide
  1. 4W4K3
    4W4K3 Notebook Evangelist
    I tried some of your advice and so far am pleased. I was not seeing C6 even on battery power. So I started closing applications and uninstalling a few things to fix it. Namely, Windows Defender and Intel Rapid Storage Tech driver. After configuring my Group Policy to disable Defender permanently, I switched to Kaspersky Free. Seems a lot smaller, with less background services.
    I also stopped using 'High Performance' power plan, and moved to 'Balanced' on battery. That , combined with the above changes, and moving the battery profile slider to "Max Battery" allows C2, C3, C6, C7, & even C8 to be active on my Acer Nitro 5. Very happy, as I am seeing as low as 0.5W power usage on 'Battery' profile and 45W on 'Performance' (if I run stock voltage).
    My next test is thermal graphite pads, which are in the mail. No more pastes for me if the pads are decent.
    EDIT - This was with dGPU idle, WiFi on, BT on, no USB accessories, screen dimmed maximum. Important to note that as soon as the dGPU wakes up, C3 is as deep as it will go. So, there is some procedure in closing apps to let the hardware 'sleep'.
  2. Vasudev
    You can use speedshift values for fine-grain tuning of CPU power consumption. 0-80 : Aggressive clocks 128: Balanced and anything above 180 is battery saver.
    4W4K3 likes this.
  3. terrorific
    terrorific Notebook Guru
    I cannot find the about section. Apparently its Windows Security now :0
  4. Vasudev
  5. terrorific
  6. 4W4K3
    I have my 'Performance' profile set to EPP value 0, and my Battery profile set to EPP value '128'. Within Windows, if I maximize the battery savings it auto dims the screen and puts a little green leaf over the battery icon in the Taskbar which is cute. Previously, I wasn't aware I could use both TS and Windows to enable/disable some power options.
  7. Vasudev
    I think battery saver is turned on regardless of battery charge thresholds. You can disable that to turn ON to 20% battery which will get rid off auto dimming.
  8. geust123455
    geust123455 Notebook Enthusiast
    Anyway to disable all C states except for C3 in order to retain Turbo Boost?
  9. geust123455
    Also when disabling all C states with the registry change I get a driver error in Device Manager under Processors reading:"A driver (service) for this device has been disabled. An alternate driver may be providing this functionality. (Code 32)". That error only manifests when disabling all C states with the registry trick from the guide. Why does that error show up and is it safe to ignore?
  10. JKnows
    JKnows Notebook Consultant
    Vasudev likes this.
