The ac adapter currently connected is not supported. system will continue on battery
Discussion in 'Alienware 17 and M17x' started by kris187, Aug 7, 2016.
  1. kris187
    kris187 Notebook Enthusiast
    hi guys,
    please help
    the ac adapter currently connected is not supported. system will continue on battery
    bios is the latest one A12. tried power drain but same problem. tried another wall outlet, same problem
    I dont have the battery connected anymore since its broken. I tried another power adapter and its giving the same error. it only happens when i play games, meaning when it requires more power then my FPS drops and i cant play the game anymore. i think its my motherboard. please help.
  2. goodstone
    goodstone Notebook Consultant
    New Power jack connection needed on motherboard.
  3. kris187
    okay thanks. i dont have warranty anymore.
  4. JAY8387
    JAY8387 Notebook Consultant
    a decent laptop repair place should be able to replace the jack
  5. kris187
    alright. ill try to find a decent repair shop. thanks for the input
  6. kosti
    kosti Notebook Virtuoso
    If it works except when playing games, then I doubt your power jack is the issue. It may be an issue with the power adapter itself. Is it a genuine Dell and how many amps is it rated for on the label? It sounds like something is drawing more current than your adapter can provide. I would also keep the battery plugged in even though it's dead.
  7. kris187
    I tried even when battery is connected and still im getting the same message. I borrowed my friends 240w power adapter from his m17x r4 and its giving the same message. It has been working since 2012. Ive attached the sticker on the adapter. Im from malaysia btw.
  8. kosti
    Under the power section of the BIOS, does it list the adapter type and wattage or does it say "unkown"? Do you get any adapter warnings on startup?
    Try doing a power drain procedure. Remove battery and power source and hold down power button for 20 seconds.
  9. kris187
    I did try those things. also in the bios it shows up as 240w
  10. kosti
    Did you try disabling power adapter warnings in the BIOS.
    If the adapter type is showing up in the BIOS and your laptop is powering up, then it's probably not the jack, unless it is not making solid contact in the center pin section and comes loose at random.
