Temps with hwinfo
Discussion in '2015+ Alienware 13 / 15 / 17' started by Ben7078, Jan 11, 2019.
  1. Ben7078
    Ben7078 Notebook Enthusiast
    I have an 6820hk and I have it over clocked to 3.9 ghz. My highest temps are 92 degrees however my average is 80ish. Are the average temps accurate as it’s always working when you see temps over 90 but I think these are just spikes and that 80 degrees is quite good under load.
    Also what is the max temp for a gtx 1080 as mine is 70 max temp and average 61.
    Thank you
  2. Vasudev
    They are accurate. 92C is max. If you want you can put 39x on all cores and how the temps fares during your workloads.
