Temperature monitor software for Acer !!
Discussion in 'Acer' started by kiriakost, Aug 16, 2008.
  1. kiriakost
    kiriakost Notebook Deity
    I like to monitor the CPU Temperature .
    I tried speedfan , good for desktops ... but it does not support well my laptop.
    Is there anything better ?
  2. Andy
    Andy Notebook Prophet
    RMClock, CoreTemp, HWMonitor, RealTemp, Notebook Hardware Control.
  3. kiriakost
    Thanks man .
    CoreTemp = will not run with Pentium M processor . :(
    I am testing the others .
  4. kiriakost
    RealTemp will not run too . :(
  5. Andy
    Well, I didn't really notice the Pentium M in your sig. Check out RMClock and HWMonitor. They will definitely work. RMClock will help you undervolt, and ammend a few CPU settings, and HWMonitor will give the temps of CPU, ACPI, GPU and HDD. Download both :)
  6. kiriakost
    Thanks Andy ...
    The free RMClock will identify the CPU , but no CPU core temp ...
    The good part with the RMClock are that it read .. the microchip , of my new battery , and gave me good details about it . :)
    Moving again for the next target HWMonitor ..
  7. Andy
    The free version of RMClock shows everything to me, and it very well supports Pentium Ms.
    HWMonitor
  8. kiriakost
    The problem are that they are not backwards compatible.
    The HWmonitor works .. but i get two values as CPU temp ...
    one high and one low ... and i do not know what to speculate as Core temp .
    TZS0 = 52C
    TZS1 = 46C
    This could be motherboard and CPU sensors .
    I can only imagine , that the low value are due the active cooling, so it must be the CPU core temp .
    I need some testing so to find out what are what .. :confused:
  9. Andy
    Backward Compatible..??
    Can you upload a screenshot..??
  10. kiriakost
    Well it looks that the Delphi
    prophecy was wrong :D
    The HWmonitor TZS0 sensor are the core temp...
    I run CPU burn-in software , and jumped at 70C - 157F
    Environment temp 30C , system idles at 50-52C .
    Screen shot of the RMClock ... yes in few minutes .
