Talking about TDP (Thermal Design Power) of the GPUs
Discussion in 'Hardware Components and Aftermarket Upgrades' started by sicily428, Aug 24, 2017.
  1. sicily428
    sicily428 Donuts!! :)
    Hi! I think we should make a guide about TDP (Thermal Design Power) of the GPUs. :)
    I'm watching so many people asking for thin and light laptops with a powerfull hardware (gtx1070/gtx1080) but they don't know consequences for that. A powerful gpu needs a good cooling system and there isn't enough space for it in a thin laptop. Thermal issues are really important for a thin laptop with a powerful hardware and thermal throttling can easily increase with a drop in performances.
    What are values for each Nvidia / Amd gpu? where can I find right values for that?
    heatsink, heatpipes and fan.
    How heat pipes work
  2. Mobius 1
    Ask someone to dump their vbios then view it using @Coolane tool and you'll see the exact TDP value.
    Most brands use 115w 1070/150w 1080 for standard. Some use higher like MSi GT series, Clevo, etc...
    Only cowards use Max-Q
  3. sicily428
  4. Papusan
    Now,its Up to the Vendors put max TGP/TDP. At least for Pascal.
    Vasudev and sicily428 like this.
  5. sicily428
    thanks! :)
    do you confirm these values? 85W TPD for a gtx1070?
    Vasudev likes this.
  6. Mobius 1
    for core, not really sure.
    @D2 Ultima
    sicily428 and Vasudev like this.
  7. D2 Ultima
    D2 Ultima Livestreaming Master
    Prema knows a lot more than I do about these things. I would take his word if he gives it.
    Sent from my OnePlus 1 using a coconut
    sicily428, Vasudev and Papusan like this.
  8. sicily428
  9. Papusan
  10. sicily428
