taking my laptop to australia, how should i charge it?
Discussion in 'Accessories' started by sook, Dec 21, 2005.
  1. sook
    sook Notebook Guru
    going to australia for a month in june, what do i need to do to be able to charge my laptop? im also taking a pda and two mp3 players that will need power.
    thanks
  2. winklier
    winklier Notebook Enthusiast
    U can by adaptors for foreign sockets
  3. Brian
    Brian Working at 486 Speed NBR Reviewer
    You just need to buy the right power converter. Radio Shack will have what you need.
  4. Chutsman
    Chutsman Notebook Evangelist
    Look at the power brick and see if the input voltage has a range of like 100 - 240 volts. If it does then you only need the correct adapter to make the plug fit in the receptacles in Australia. I believe they are called V-shape flat, whereas your power brick is parallel flat. But do a Google search to be sure.
    If your power brick does not have that range then you will also need a transformer to reduce the 240 volts in Australia to the 110/120 that we use here in the USA.
