Take Full Control of your Razer Blade w/no PL Throttling
Discussion in 'Razer' started by David Kirchik, Mar 8, 2019.
  1. Thysanoptera
    Thysanoptera Notebook Consultant
    9750h with power limits removed is actually pretty close to stock 8700k, it scales almost linearly with frequency, I'm getting 8700k/9750h ~ 1390/1290 CB15 ~ 4.3/4.0 GHz full turbo frequency. Around 7% slower than desktop, pretty good in my book. I'd get rid of the desktop if it wasn't for Nvdia drivers crashing my system twice a day with 2080Ti in Core X. Vega FE is perfectly stable in the same setup, but too slow
  2. Papusan
    Sure.
    38 and 39x http://forum.notebookreview.com/thr...gtx-1080-upgrade.814711/page-66#post-10763864
    40x http://forum.notebookreview.com/thr...5-owners-lounge.815492/page-147#post-10763407
    41x http://forum.notebookreview.com/thr...-w-i9-8950hk-to-the-max.820711/#post-10773495
    Stock clocks (43x on all cores)
    Edit... i7-8750@3.9GHz +1300
    https://hwbot.org/submission/3964437_kill4l_cinebench___r15_core_i7_8750h_1308_cb
    jc_denton likes this.
  3. Thysanoptera
    But I'm not sure what you're trying to prove? So your 8700k in fine tuned laptop with custom BIOS has CB15 score 70 points higher than my own, bog standard 3 year old desktop, is that such a big deal?
  4. Papusan
    You don't need custom bios to perform correct in benchmarks with stock or below clocks. 70cb is +2 bin. And for the records.. The 8700K was used in an laptop from 2015. Aka +4 years old.
  5. Thysanoptera
    My desktop is actually two years old, from 2017, right after official 8700k release. And I wasn't comparing stock to below clocks but my Razer Blade 15 to my desktop. Both not setup specifically to run benchmarks and sure as hell I'm not going to strip every piece of background software now. Besides you have some golden sample running with -200mV. Even taking your score into consideration, the 9750h is within 11% of 8700k which is still pretty damn close, considering how much less power it consumes.
    And whats with that 2015, Skylake was released at that time.
    EDIT - the max power in throttlestop, was it really 52W@4GHZ? Damn, you have some magic CPU that can handle voltage that low.
  6. Thysanoptera
    @Papusan - That's my 8700k at 4GHz during CB15 at stock voltage. Whatever you have, I wouldn't call it a stock 8700k.
  7. Papusan
    My chips is binned 5.3GHz. But this doesn’t matter with stock clocks or below in benchmarks. Low vid due binned Cpu + great undervolt as well low temps will reduce package power.
    See above. Voltage doesn’t matter in bench with low clock speed and well below throttling temp.
  8. jc_denton
    jc_denton V̖̟en̰g̻̼̰̩͙ea̲n̪c̭e̼ ͍̘̤͓̟̤Is̙͔ ̤Mi̻̭̣͎͍ͅn̰ḙ
    You should also take temperature into consideration, as the chip will run more efficient.
  9. Joikansai
    Joikansai Notebook Deity
    Come on buddy I was jumping happy knowing my jokebook cpu having almost similar Desktop performance:tears:
    Happy enough though can move super tight Razer Power Limit and surpass 1200 marks:notworthy:
    Papusan likes this.
  10. Papusan
    That’s correct brother. People forget efficiency. See... The power consumption rises with temperature (because of I2R loss). So if his chips run the same test but at much higher Cpu temp, the power consumption will be higher due higher temps.
    Same will happen if you run sub zero temp with phase cooling etc. Chips running -30C vs 0 and you’ll see lower power consumption. This isn’t magic science.
