Take Full Control of your Razer Blade w/no PL Throttling
Discussion in 'Razer' started by David Kirchik, Mar 8, 2019.
  1. custom90gt
    What is your memory? I have my crucial 3200mhz CL 16 running fine but did have to run it at the rated 1.35V. I may slowly lower that and see if I can maintain stability.
  2. somejoshdude
    somejoshdude Notebook Consultant
    Please see the attached dump
    Hyperx 32GB (2x16GB) XMP1 3200 CL20 XMP2 2933 CL17
    EDIT* I am unsure based on the micron chips used if it would be safe to apply 1.35
  3. somejoshdude
    with -50 on slope (sorry) -40 u/v on core (bios)
  4. somejoshdude
    Doh' it is always safe with overclocking ram... New image incoming after I test stability.
    EDIT* no dice up to 25 mv core, will fiddle with it later tonight.
    However with 50 IMON slope -50mV on core and XMP 2933 CL17...
  5. somejoshdude
    • VCCIO and VCCSA voltages for Intel from 1.15v to 1.2v or 1.25v.
    That did the trick for 3200 xmp - now to overclock =D
    amihail91, custom90gt and wireproof like this.
  6. amihail91
    amihail91 Notebook Evangelist
    How are you setting the VCCIO and VCCSA on these laptops?
  7. SrAlu
    SrAlu Newbie
    Anyone knows if this works with the new Razer Blade Stealth with 1165G7 (late 2020)?
    This mod could turn this mashine into the perfect eGPU laptop
  8. Reedus
    Reedus Newbie
    If I'm not wrong, the 2020 RB (not sure if also Stealth ones) has encripted BIOS, so atm there isn't any unlocked BIOS for 2020 RBs.
    wireproof likes this.
  9. somejoshdude
  10. amihail91
    Interesting - do you think you're adding any heat doing this?
    I've been able to get Hyper X sticks to 2933 @ 1.3v - do you think it needs the extra voltage here to go higher?
