Take Full Control of your Razer Blade w/no PL Throttling
Discussion in 'Razer' started by David Kirchik, Mar 8, 2019.
  1. Nashi
    Nashi Newbie
    Also have this problem..
    where can I find the 0x3DC , kind of new to bios stuff..
  2. Thysanoptera
    Thysanoptera Notebook Consultant
    This variable is different on every machine, this is just how it looks like on mine. I had to manually hex edit the dump and change all "Suppress if" in the spots that I needed after swapping SSD.
  3. Nashi
    Nashi Newbie
    got it, is there any keyword to search for so search the correct things to modify?
  4. Thysanoptera
  5. stranula
    stranula Notebook Consultant
    To fix the options not showing with a 3rd party cloned SSD, I had to just change all suppress if checks.
    Unfortunately, the way I ultimately was able to get it to work with a 3rd party cloned ssd was by changing every suppress if to FF00. Where this gets even more tiresome, and where I actually got everything unlocked, was checks that say supress if 0x### equals 0x1 or 1600 or 1700. Those 1600 and 1700 were what were keeping it hidden for me. Which version of RB15 do you have?
  6. Nashi
    Nashi Newbie
    thanks, I'll look into it tonight
    RBS13 late 2019 (white)
  7. waynerdog
    waynerdog Newbie
    I have an early 2019 RBS and successfully modded the bios by following the first post. At first, I was able to get clock speeds of 4.4 ghz with turbo and limited it to 3.8 ghz using TS. In both cases, I'm getting massive stutter in any game I play, with the fps constantly fluctuating. This was not the case before flashing the bios. I'm using the Razer Core V2 with a GTX 1070. Thanks for the help.
    Edit: In case anyone else runs into the same problem, I fixed it by disabling the MX150 in the device manager. It's strange that this wasn't a problem before flashing the bios though.
  8. signer
    signer Newbie
    I'm planning to install Windows from scratch on the RBS2019late. If as you say, the Razer modded the OS registry, what will I lose even if I reinstall all the available software from the Razer driver website?
  9. maven1975
    maven1975 Notebook Evangelist
    I just swapped out my RBS 2019 for a MW RBA 15 this evening. (Cheaper = 1250 @ Best Buy!!!)
    I had used this tweak on the RBS without issue.
    It did indeed help performance! 2200 CB r20 10 runs. (Solid)
    On to the RBA 15 2019...
    I have triple checked all entry's and am having BSOD's 15-30 seconds after boot.
    I can eliminate the BSOD's by reverting the Bios settings to default.
    After reading through this entire thread, It seems that I am not alone with this.
    Has anyone found the reason for this? Does anyone have a suggested tweak or value change to try?
    Thanks in advance!
  10. sYnSBG
    sYnSBG Notebook Enthusiast
    is it possible to undervolt again after do this on my rbs early 19? i mean 860cinebench 15 for 8565u is very impressive without undervolt
