Take Full Control of your Razer Blade w/no PL Throttling
Discussion in 'Razer' started by David Kirchik, Mar 8, 2019.
  1. HandsomeGhost
    HandsomeGhost Notebook Enthusiast
    Awesome. I have the Razer 15 Early 2019
  2. stranula
    stranula Notebook Consultant
    hackness, el3c and HandsomeGhost like this.
  3. el3c
    el3c Notebook Enthusiast
  4. stranula
    I believe it can be enabled. The problem with me having a look is that I have no way to test it. The best I can say is follow the guide and see where it takes you.
  5. hackness
    hackness Notebook Virtuoso
    Looks great!
  6. veahavarde
    veahavarde Notebook Enthusiast
    Has anyone here dissasembled the lcd panel from a Blade 15 here? I am about to try a 144hz panel on my base 2018, but I am not sure how to dissasemble the screen chassis.
    Edit: Woops, I thought this was the owners forum. Sorry.
  7. Rage1573
    Rage1573 Newbie
    For anyone wondering, the late 2019 Blade Stealth 1650 max-q benefits from this massively.
    In Cinebench r20 it went from 1209 to 2117. Constant 2182 MHz with no throttling and the thermals aren't terrible with stock paste, around 80-85 degrees under full load.
    Battery life seems unaffected also at about 9 hours of general web surfing and productivity.
    Thanks to OP for sharing!
    Also is there any way to determine the "corrected" Watts the cpu is pulling? Math or another program?
    pau1ow likes this.
  8. amihail91
    amihail91 Notebook Consultant
    Can you share your exact timings? I imagine all our Blades could benefit from your settings or near to them anyway.
    If anything goes wrong a CMOS reset will fix it anyways. :)
  9. stranula
    That is 100% dependant on your memory modules. Mine are not the stock ones, so will be of no use for you. You just have to test setting and see what you get. There are only a handful of options to mess with, change 1 at a time, a step at a time, making note of what works and what doesn't.
    amihail91 likes this.
  10. amihail91
    At least share your speed and CL :)
