TactX buttons on AW 15 R3 not working
Discussion in 'Alienware' started by Spin360, Jan 20, 2018.
  1. Spin360
    Spin360 Notebook Enthusiast
    So this has been like that for a while now, my tactX buttons do not work.
    What I mean by this is, that the buttons have the LED, I can change the color, but in the TactX software all I can do is change the color of the three profiles. The profiles are empty and I cannot chose any keys or something - see attachment.
    Is it possible I did not properly connect the macro keys when reassembling the laptop after repasting? What else could it be?
  2. Spin360
  3. MogRules
    MogRules Notebook Deity
    If the cables were not connected I wouldn't think you would be able to change the color at all.
    Have you uninstalled and reinstalled the Command Center? If so I had a similar situation when I first got my R4 which I initially thought was the actual TactX keys and Alienware even sent me a new TactX keys section to no avail. In the end they even shipped me a new laptop as we couldn't figure it out and I popped out the SSD from the R4 into the new one and the problem moved with it lol so it wasn't hardware in my case. To be honest I never found out what the EXACT problem was but I know it was software. Something I was installing was interfering with Command Center , and it was something I was installing but I don't know what. In the end with a completely clean install of Windows CC worked fine, but after installing all of my programs and usual stuff , when I tried to change the color on the TactX keys or interact with them at all in CC the app would crash. Eventually on a fresh install without installing any of my usual stuff I got it to work , but I have never been able to peg down exactly what was causing it, although I am pretty sure it was software. I messaged on of Alienware's software guys on Reddit, the guy that built CC and he agreed, the error message was pointing to software problems as well.
    Sorry I can't be of more help....I always thought it had something to do with installing old versions of .net framework to run some really old games I have but I was never able to confirm it.
    I know reinstalling Windows is a PITA, but if it solves the issue it might be worth it.
Similar Threads - TactX buttons working
  1. h00vertime
    2
    391
