T61/X61 SATA II 1.5 Gb/s cap - willing to pay for a solution
Discussion in 'Lenovo' started by dubak, Feb 14, 2010.
Would you be willing to spend some money for a solution enabling SATA II on your T61/X61
  1. YES
    228 vote(s)
    71.3%
  2. NO
    92 vote(s)
    28.8%
  1. middleton
    middleton Notebook Consultant
    What error message did you get? If it's "BIOS image file cannot be found.", then you use wrong BIOS which is not intended for your machine.
    Tell me your current BIOS Version and Embedded Controller Version (Determining which version is installed).
  2. Lyran1337
    Lyran1337 Newbie
    I own a T61 7661-CTO 14.1" widescreen with 1394 and without Bluetooth. As my device is not listed in your compatibility list, I wanted to ask if I might use your Bios file for T61's for my Thinkpad.
    Thanks in advance
  3. middleton
    All T61/T61p models use one common BIOS. According to Lenovo you may use this BIOS for ANY T61/T61p machine.
  4. Lyran1337
    Lyran1337 Newbie
    Thank you very much, didn't know that. I'm going to try the BIOS in the next couple days.
  5. defuse
    defuse Newbie
    Hi, Middleton thanks for the response.
    I get the, "BIOS image file cannot be found".
    BIOS Version - 2.19
    Embedded Controller Version 7KETB9WW
  6. middleton
    ThinkPads that have 7KETxxxx BIOS ID:
    R61 (14.1" widescreen without IEEE 1394): 7732, 7733, 7734, 7735, 7736, 7737, 7738
    R61 (15.4" widescreen): 8914, 8918, 8919, 8920, 8927, 8928, 8929
    R61i (15.4" widescreen): 8918
    In theory, you should use BIOS for these machines (last row in the table, see page 8). But Lenovo doesn't mention "ThinkPad R61i 14.1 inch widescreen without IEEE 1394" in the supported models list (see here). However you can find this laptop in the supported models list here.
    Don't know what it means. Anyway, if you decide to flash the patch, then you do it at your own risk. Maybe Lenovo had serious reasons to exclude your ThinkPad from the list of supported models.
  7. cxd9615gb
    cxd9615gb Newbie
    middleton, thanks a lot for this BIOS.
    My X61s arrived damaged a few weeks ago, just replaced the broken parts today and want to thank you for your work. Enable SATAII allowed me to install a Crucial M4 SSD and this thing really flies now.
    :D :D
    Will definitely send a donation your way next payday.
  8. internoc
    internoc Newbie
    Middleton -
    For some unknown reason I cannot get the BOIS to load - error 99 (170)
    I have tried removing Removing TPM, stopping bitllocker (which should not be active - using 64 bit Win 7), always errors out at end.
    T61 (7663-WDM) 64 bit version W7
    TIA
  9. miro_gt
    miro_gt Notebook Deity
    ^ as far as I remember, if you're using the 64bit OS then you need to make a bootable CD to flash your laptop.
    No such problem when using 32bit OS.
    - shall I not forget to send a ton of thanks to middleton again for the wonderful work :D
  10. internoc
    internoc Newbie
    Middleton -
