T60 wireless problems
Discussion in 'Lenovo' started by bm99, Sep 15, 2006.
  1. bm99
    bm99 Notebook Enthusiast
    Hi all.
    I just got a T60 this week and Im likin it a lot. I am however having a few problems with the wireless on this machine. When I am connected to wireless internet, the wireless card keeps shutting off every few minutes and I have to restart it myself using Fn+F5.
    I downloaded the latest drivers for the wireless card and access connections, but I am still having the same problem. Does anyone have any possible solutions to this issue?
  2. bman22
    bman22 Notebook Consultant
    I uninstalled Access Connections and let Windows handle my wireless networks.
    It seems to have fixed my disconnecting problems.
  3. ZaZ
    You might want to try the Intel driver as well. It has also has its own connection manager. I also found that Norton on both the Z61m and n100 often interfered with network connections. NetVeda is a good free firewall you may wish to check out. Good Luck.
  4. pharper
    pharper Newbie
    I have also just got a T60 and while I like the laptop I have the following problems.
    If the device is running on battery, my wireless card works fine. As soon as I plug into mains power, the wireless card no longer functions. That is not to say the card becomes disabled, it just doesn't work.
    I also have a Verizon card. If I plug the device into the mains, the VZW card becomes unstable and disconnects every 1 - 2 minutes.
    Anybody seen similar behaviour?:mad:
  5. Ethyriel
    Ethyriel Notebook Deity
    Check in device manager, Windows may be allowed to power manage the device.
  6. nhatnam4
    nhatnam4 Newbie
  7. Bluesman
    Bluesman Notebook Enthusiast
    I purchased the T60 widescreen with the Atheros 11a/b/g/n Wireless LAN Mini-PCI Express Adapter. I am using a Dell router.
    It picked up my home wireless network literally minutes after I booted up for the first time ... no problem at all. Then, the next time I boot up, I get nothing ... I poke around with the wireless network settings (presumably Windows XP based) and get it to work again.
    Tonight ... nothing again, and "Windows cannot configure the wireless connection" nor even locate it. I turn on ThinkVantage Acces Connection, and it works like a charm ... I'm back on, surf for a while, start poking around to see if I need some updates ...
    I lose the connection again. I use the same process in ThinkVantage and find link a half dozen wireless networks/signals). I locate the one that looks like mine (strongest connection/100% as I am standing next to it), and it says I am connected, but IE keeps giving me the same error message.
    Now, ThinkVantage is not even finding any wireless networks, and Windows still cannot "configure" anything.
    Any ideas?
  8. Bluesman
    So I head upstairs, not particularly feeling like being defeated by technology tonight ... reboot ... plug it in ... click through the Windows wireless options, restart the ThinkVantage Access, and ... I am back in business. I find 3-4 wireless networks (two encrypted, one open), select the open, and I am on. Candidly, I am not entirely sure that I am on my own network. I suspect that the plugging in had something to do with it (?), but that would not seem logical to me.
    Again, any words of wisdom for the remedial group in wireless technologies would be appreciated.
  9. drKimura
    drKimura Newbie
    nhatnam4, I have the Atheros adapter. Can you give the instruction for that please?
    Thanks!
  10. JungleboyJ
    JungleboyJ Newbie
    I have a T60p Widescreen (8743-CTO) system that I purchased back in April. I love the system, but shortly after I received the system I started seeing problems with my Atheros Wireless LAN Mini-PCI Express a/b/g/n adapter not reconnecting to the network after being in standby mode much like those described above. I have been working with IBM's tech support (which has provided excellent service) on this problem ever since.
    We have tried reloading the OS (which resolved a hang problem I was having when the network connection would be dropped), tried two different wireless cards and even replaced the planar board on the system. Unfortunately none of these changes have completely resolved the issues I have been seeing. I have found a couple of things that seem to help reduce the frequency of this problem.
    1) Set the 'Power Save Mode' for the Atheros a/b/g/n Adapter to 'Off'. This seems to resolve the Windows Explorer hangs I was seeing.
    2) Go into Access Connections, Configure -> Global Settings and uncheck 'Enable automatic wireless LAN radio control'.
    3) Follow the directions above for disabling the Intel PRO/1000 PL Network Connection's Deep Smart Power Down feature.
    With the changes above in place I only see the Wireless LAN problem after standby one out of every 6 to 8 times.
    I continue to work with tech support on this issue. They escalated it to their 'Hot Line' this last Wednesday (6/6/07) as I was one of 4 or 5 people that had been through similar steps but were still seeing the problem. I hope to hear back from them soon.
    I will post updates here as I learn more about possible resolutions to this problem.
