T60 Fan Error?
Discussion in 'Lenovo' started by gog, Jan 25, 2008.
  1. gog
    gog Newbie
    When I tried to boot up my T60 a couple days ago, a Fan Error message appeared and the laptop automatically shut down. This problem continues until today when to my surprise, the laptop boots up fine. Anyone familiar with this problem and know what might cause this. This is fairly new laptop, only 1 month old so I don't think laptop aging is the cause. Should I try to have the laptop service by asking IBM/Lenovo to replace the fan? The laptop works fine now but I keep all the important work related stuffs in the laptop and hate knowing that problem like this might happen again in the future :(
  2. derf
    derf Newbie
    I am getting this error also on several occasions. Each time the notebook has had some mechanical stress, either a mechanical shock (dropped my bag a few inches to the floor), or in the last case, a thermal shock (left it in a cold vehicle for a few hours). I think the fan is sticking and not starting up.
    A sharp rap from my knuckles on the rear of the case near the fan exhaust seems to temporary fix the problem.
    Anyone know the part no. of the fan, where to get it, install procedure?
    I expect more reliability than this for a unit of this price.
  3. klutchrider
    klutchrider Notebook Evangelist
    I think it's better to have a pre-cautionary message that alerts you of the issue then to just run it and ignore that the fan isn't working. Like you said after a reboot it fixes itself, if it is less than a year I would definitely call up Lenovo's tech support and see what they stand on the issue and hopefully provide a fix. So far on my laptop I have not received any errors I couldn't fix. *knocks on wood*
  4. optomos
    optomos Notebook Evangelist
    Usually means the fan is failing or there was something blocking the fan from turning. It will eventually fail though so I would consider calling Lenovo and having it serviced, otherwise one day it will give that same error message at POST and never go beyond that point.
