T440s LG/AUO Screen replacement
Discussion in 'Lenovo' started by guydbg, Jan 23, 2014.
  1. grosmar
    grosmar Notebook Enthusiast
    Maybe did you face the same problem with intel driver? Did you find any solution?
  2. poorbast
    poorbast Newbie
    I swapped the 1600x900 panel on my T440s out with the AOU b140HAN01.2 which works great. I adjusted the color profile in Win10 to not be as yellow however since installing it I've noticed the screen is kind of dim even with the brightness cranked all the way up. Anyone else experience this? I love to figure out a way to make it brighter.
  3. vint.vint
    vint.vint Newbie
    I use ubuntu, no problems with the brightness. for me it even a lot, I use the first level), I launched the windows on this laptop only once when it was new, the next day I replace the screen and install ssd.
    I would try to boot with usb, which installed windows and try to change the brightness of there, if there will be all ok. it should help to reinstall windows.
  4. clasho
    clasho Notebook Enthusiast
    So what's the different between AUO "...1.1", "...1.2" and "...1.3" version?
