T420 w/ Kingson Hyper-X 1866 - Works!
Discussion in 'Lenovo' started by hasaarin, Sep 21, 2011.
  1. hasaarin
    hasaarin Notebook Enthusiast
    Hi All,
    Just quickly to clarify that my brand new HyperX 1866 ram works at 1866Mhz on the T420. Like a charm.
    Regards,
    Harry
  2. John Ratsey
    Interesting. :eek: What are the memory bandwidth, memory latency and video memory bandwidth according to SiSoftware Sandra.
    John
  3. hasaarin
    Hi,
    here go some results. apologies for the long post, but there you have it. Detailde to the max.
    Regards,
    Harry
    Memory Benchmark
    Benchmark Results
    Aggregate Memory Performance : 23.59GB/s
    Integer B/F AVX/128 Memory Bandwidth : 23.57GB/s
    Float B/F AVX/128 Memory Bandwidth : 23.62GB/s
    Results Interpretation : Higher scores are better.
    Binary Numeral System (base 2) : 1GB(/s) = 1024MB(/s), 1MB(/s) = 1024kB(/s), 1kB(/s) = 1024 bytes(/s), etc.
    Details:
    Windows Experience Index
    Current Chipset/Memory : 7.6
    Performance vs. Speed
    Aggregate Memory Performance : 12.95MB/s/MHz
    Integer B/F AVX/128 Memory Bandwidth : 12.93MB/s/MHz
    Float B/F AVX/128 Memory Bandwidth : 12.96MB/s/MHz
    Performance vs. Power
    Chipset(s)/Memory Power : 17.710W
    Aggregate Memory Performance : 1364.09MB/s/W
    Integer B/F AVX/128 Memory Bandwidth : 1362.62MB/s/W
    Float B/F AVX/128 Memory Bandwidth : 1365.56MB/s/W
    Capacity vs. Power
    Memory Capacity : 463MB/W
    Assignment : 23.7GB/s
    Scaling : 23.81GB/s
    Addition : 23.32GB/s
    Triad : 23.43GB/s
    Data Item Size : 16bytes
    Buffering Used : Yes
    Offset Displacement : Yes
    Bandwidth Efficiency : 79.96%
    Assignment : 23.82GB/s
    Scaling : 23.83GB/s
    Addition : 23.43GB/s
    Triad : 23.4GB/s
    Bandwidth Efficiency : 80.06%
    Performance Test Status
    Result ID : Intel Core (Sandy Bridge) Mobile DRAM Controller (Integrated Graphics); 2x 4GB Kingston 9905428-048A00LF DDR3 SO-DIMM (1.87GHz 4% OC) PC3-14200 (11-11-11-32 5-43-14-7)
    Computer : Lenovo 4180A32 ThinkPad T420
    Platform Compliance : x64
    Total Memory : 7.78GB
    Memory Used by Test : 3.89GB
    NUMA Support : No
    SMP (Multi-Processor) Benchmark : No
    Total Test Threads : 2
    Multi-Core Test : Yes
    SMT (Multi-Threaded) Benchmark : Yes
    Processor Affinity : P0C0T0 P0C1T0
    System Timer : 2.43MHz
    Page Size : 4kB
    Features
    SSE Technology : Yes
    SSE2 Technology : Yes
    SSE3 Technology : Yes
    Supplemental SSE3 Technology : Yes
    SSE4.1 Technology : Yes
    SSE4.2 Technology : Yes
    AVX - Advanced Vector eXtensions : Yes
    HTT - Hyper-Threading Technology : Yes
    Chipset
    Model : Lenovo Core (Sandy Bridge) Mobile DRAM Controller
    OEM Device Name : Intel Core (Sandy Bridge) Mobile DRAM Controller
    Revision : A10
    Front Side Bus Speed : 100MHz
    Width : 20-bit / 20-bit
    Maximum Bus Bandwidth : 400MB/s
    Logical/Chipset Memory Banks
    Bank 0 : 4GB DDR3 SO-DIMM 11-11-11-32 5-43-14-7 1T
    Bank 2 : 4GB DDR3 SO-DIMM 11-11-11-32 5-43-14-7 1T
    Integrated in Chipset : Yes
    Shared Memory : 66MB
    Channels : 2
    Memory Bus Speed : 2x 933MHz (1.87GHz)
    Multiplier : 28/3x
    Width : 64-bit
    Integrated in Processor : Yes
    Maximum Memory Bus Bandwidth : 29.16GB/s
    Memory Module(s)
    Memory Module : Kingston 9905428-048A00LF 4GB DDR3 SO-DIMM PC3-14200S DDR3-1778 (11-11-11-32 5-44-14-7)
    Memory Latency
    Benchmark Results
    Memory Latency : 76.7ns
    Decimal Numeral System (base 10) : 1s = 1000ms, 1ms = 1000µs, 1µs = 1000ns, etc.
    Speed Factor : 59.70
    Results Interpretation : Lower scores are better.
    Details:
    Cache Information
    Integrated Data Cache : 3clocks
    L2 Cache : 10clocks
    L3 Cache : 27clocks
    Memory Latency : 0.04ns/MHz
    Memory Latency : 4.33ns/W
    Detailed Benchmark Results
    1kB Range : 1.3ns / 3.2clocks
    4kB Range : 1.3ns / 3.2clocks
    16kB Range : 1.3ns / 3.2clocks
    64kB Range : 3.9ns / 9.6clocks
    256kB Range : 4.5ns / 11.2clocks
    1MB Range : 10.7ns / 26.6clocks
    4MB Range : 64.1ns / 159.7clocks
    16MB Range : 73.5ns / 183.3clocks
    64MB Range : 76.7ns / 191.1clocks
    Memory Access : Random
    Processor
    Model : Intel(R) Core(TM) i5-2520M CPU @ 2.50GHz
    Speed : 3.19GHz
    Peak Processing Performance (PPP) : 25.52GFLOPS
    Adjusted Peak Performance (APP) : 7.66WG
    Cores per Processor : 2 Unit(s)
    Threads per Core : 2 Unit(s)
    Type : Mobile, Dual-Core
    Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
    L2 Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
    L3 Cache : 3MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 16 threads sharing
    Memory Controller
    Speed : 3.2GHz
    Chipset
    Revision : A10
    Channels : 2
    Multiplier : 28/3x
    Width : 64-bit
    Video bandwidth
    Benchmark Results
    Aggregate Memory Performance : 9GB/s
    Internal Memory Bandwidth : 19.74GB/s
    Data Transfer Bandwidth : 4.15GB/s
    Type : D3D11 SM5.0
    Details:
    Bandwidth Efficiency : 67.71%
    System to Device Bandwidth : 6.84GB/s
    Device to System Bandwidth : 2.52GB/s
    3D Graphics Performance : 6.4
    Aggregate Memory Performance : 4.97MB/s/MHz
    Internal Memory Bandwidth : 10.83MB/s/MHz
    Data Transfer Bandwidth : 2.28MB/s/MHz
    Device(s) Power : 11.670W
    Aggregate Memory Performance : 794.26MB/s/W
    Internal Memory Bandwidth : 1732.31MB/s/W
    Data Transfer Bandwidth : 364.18MB/s/W
    Capacity vs. Power
    Memory Capacity : 5.48MB/W
    Result ID : Intel(R) HD Graphics Family (12 SM4.1 650MHz, 64MB DDR3 1.87GHz 128-bit, Integrated Graphics)
    Total Memory : 64MB
    Memory Used by Test : 12.78MB
    Total Test Threads : 1
    Video Adapter
    Model : Intel(R) HD Graphics Family
    Driver Version : 8.15.10.2418
    Chipset : GT3000M
    Speed : 650MHz
    Shader Speed : 650MHz
    Peak Processing Performance (PPP) : 15.6GFLOPS
    Adjusted Peak Performance (APP) : 14WG
    Unified Shaders : 12 Unit(s)
    Raster Operation Units (ROP) : 1 Unit(s)
    Texture Mapping Units (TMU) : 2 Unit(s)
    Maximum Pixel Fillrate : 650MPix/s
    Maximum Texture Fillrate : 1.3GTex/s
    Total Memory : 64MB DDR3
  4. John Ratsey
    Thanks, to compare with my results using 2 x 4GB 1333MHz RAM:
    Memory Benchmark
    Average 18 GB/s
    Memory Latency
    85.9 ns
    Video bandwidth
    8 GB/s
    So you are getting a big boost to the raw memory bandwidth but a lesser boost to latency and the video memory bandwidth.
    John
  5. psychopomp1
    psychopomp1 Notebook Consultant
    Errrr....don't you mean that he's getting a boost in all three departments?
    Memory Benchmark
    Memory Latency
    Video bandwidth
  6. Gorgonesh
    Gorgonesh Notebook Enthusiast
    You might want to reread what you quoted. He DID state that there was a boost in all three aspects, just that one wasn't as large of a boost. ;)
  7. isterika
    isterika Notebook Enthusiast
    what about power usage? more speedy RAM = Less battery life? or it's doesn't play so big role?
  8. psychopomp1
    Sorry, i did indeed misread what John Ratsey wrote. Apologies John:)
  9. hasaarin
    Hi,
    Battery consuption is not really an issue with me. I have it pluged in all the time, or most of the time..... However, seeing as the memory runs at the same voltage ( 1.5v ), as as supposedly takes less time to execute a given process, it should in theory use slightly less energy..... ;) Take the same analogy for cars and engines..... a 1.6 TDI engine at 120 km/h with 90Hp consumes more than the same engine with 110 Hp. You need less power to achieve the same results..... Think about it. Same principle appies to virtualization, and other areas in computing.
    Regards,
    Harry
  10. John Ratsey
    Interesting theory. I believe that RAM power consumption should be in proportion to the frequency - faster RAM has more access functions per second. However, it will take fewer seconds to complete the activity, so no overall power increase (assuming that RAM idle power consumption is small). Also, the CPU can be getting back to sleep sooner, which is another power saving.
    John
Similar Threads - T420 Kingson Hyper
  1. peter1790
    795
