T410 and 3 Monitors
Discussion in 'Lenovo' started by techadventures, Mar 27, 2011.
  1. techadventures
    techadventures Notebook Consultant
    Hey All
    Quick question for you all. I have a t410 with Optiumus. I also have the ThinkPad Mini Dock Plus Series 3. My question is can I set up 3 displays...One will be a Dell 30" display with the dell active display port to dvi adaptor plugged into the display port, and then 2 x 24" monitors on the dvi ports on the dock. I think this is possible but just want to confirm.
    Thanks
  2. rcjh
    rcjh Newbie
  3. techadventures
    that kinda sucks..You would think with having 2 dvi and 2 display port that 3 digital outputs would be possible
  4. princealyy
    princealyy Notebook Evangelist
    I think it might have something to do with the limitations of the laptop as well..
  5. Pseudorandom
    Pseudorandom Notebook Evangelist
    this.
    I believe doing a triple display setup the way you are doing requires and AMD GPU that supports Eyefinity regardless of using Eyefinity or not.
  6. lead_org
    lead_org Purveyor of Truth
    You can run 4 monitors from the Optimus equipped Thinkpad (one of them is the internal LCD), the Eyefinity can only do three.
  7. halobox
    halobox Notebook Deity
    Actually, you can run four external.
  8. techadventures
    so do you think my setup will work?
  9. halobox
    I don't think you can use two DVI and one DisplayPort connector on the dock at the same time. But I haven't tested it.
  10. lead_org
    dvi/displayport combo only supports one output per one set, so if you use a dvi then the displayport right next to it gets disabled. So basically the dock can only support two digital video connection at the same time.
    @Halobox, can you use the displayport on the laptop when you have three screens running off the Dock series 3 plus?
