t400s Headset combo-jack splitter?
Discussion in 'Lenovo' started by pem69, Sep 4, 2009.
  1. pem69
    pem69 Notebook Consultant
    Question about the T400s. I know it has a Headphone/Microphone combination port, that can take standard 3.5mm headsets. However, I'm wondering if there are any connectors that can take a preexisting headset with headphone+microphone as separate 3.5mm plugs and combine them into the single jack. Searching has proven mostly unfruitful, I get a lot of "plug in your headset, and it adds a microphone" or "split into 2xaudio connectors" adapters, neither of which would work.
    Anyone seen these around? They can't be particularly hard to manufacture...
  2. jaakobi
    jaakobi Notebook Evangelist
    I think you'll have to make one yourself. I don't think there's much of a market for such adapters. I think they figure most people would just use the built in microphone, or use iPhone type headsets, or use Bluetooth headsets, or whatever.
  3. pem69
    That's a pity. The couple of times I've tried to re-solder any headphone cables, it's been a massive PITA. Any one else have ideas?
  4. furrycute
    furrycute Notebook Evangelist
    Does the T400s have separate headphone out, microphone in jacks?
  5. furrycute
    Just looked on the Lenovo homepage. Only one audio in/out jack. Didn't even know about this before. This is bad audio wise, big time.
  6. twister
    twister Notebook Evangelist
    Have you tried contacting Lenovo to see what they recommend?
  7. pem69
    Yes, it's a single audio jack, standard for many headsets, but it's sometimes nice to have separate headphone/microphone components, if you have an older, but still quality headset. It's not especially bad, since regular headphones will plug in and work exactly as expected; there are only problems if you want to use your own microphone.
    I did call and ask, but the guy wasn't particularly helpful - he told me the machine had a microphone (two, in fact!) built into the screen. I told him I knew, but that sometimes you want to use another one. I guess I could try again, and see if I get a different rep.
  8. pem69
  9. furrycute
    The smaller x301 has separate audio out and microphone in jacks, I don't understand why Lenovo chose the combo jack on the physically larger T400s. This is a major bummer.
  10. mtalinm
    mtalinm Notebook Consultant
    they did it because lots of business users (their target market) have iPhones or Blackberries with 1/8" combo headphone/microphones. easy to plug those into the machine and be able to carry on Skype conversations.
    btw, the dual microphones on the t400s are *great*. I use them with Dragon voice recognition, and the quality is surprisingly good.
    If you have a t400s and really need separate components, the dock has them.
