T20 CPU fan problem
Discussion in 'Lenovo' started by mccma2003, Dec 2, 2004.
  1. mccma2003
    mccma2003 Newbie
    I have IBM Thinkpad T20 notebook. MY notebook has a problem with its CPU fan. After I press Power button, CPU fan runs about 10 seconds and then off. It won't back on again until its automaticly shut off (overheat).
    Anyone has any idea? I have already updated the BIOS(latest one).
    Thank you!
  2. Old Bob
    Old Bob Notebook Enthusiast
    This is very confusing !!
    "It won't back on again until its automatically shut off (overheat)"
    1) What wont back on again ?? - The fan??
    2) until its automatically shut off (over heat). The Thinkpad ??
    You stated the fan is already stopped.
    The fan does not run 100% of the time. So when you first power up, before the interior warms up, the fan will probably be off.
    But if the fan is working properly, you should feel warm air [out the side] BEFORE the Thinkpad overheats.
  3. mccma2003
    mccma2003 Newbie
    I meant The cpu fan is on right after I press power button but only about 10 seconds.
    It stops and won't run again...
    Please help..
    Thank you!
  4. Tech
    Tech Newbie
    ERROR
    0175: Bad CRC1, stop POST task.
    This error is shown in my computer when I power on it and it does not boot, can somebody help me about this problem how can I fix it or where to get some help to fix it. Thank You.
    Computer Sience, & IT.
  5. markymarc
    markymarc Newbie
    Hi guys!
    I actually have the same problem with my t20. i sent it a couple times to ibm but they coulndt find the problem. i fear its the mainboard.
    anyways. i opened up my laptop and took out the fan. i noticed that the thermal pad between the cpu and the fan got old, so i bought a thermal sheed, layered it a couple times and put it back in. actually i bought a total new fan just to be certain. but still the problem is there and still the cpu clearly overheats. there is an exterme heat coming from the cpu and the pcmci card bay.
    does anybody have an idea what that can be? any help? cause i am ready to dumb my notebook and call it a day.
    Marc
  6. saulosilva
    saulosilva Newbie
    Anyone already resolve this problem ? My machine have the same problem .
  7. markymarc
    markymarc Newbie
    no. i actually gave up on it and save on a new laptop...
  8. yprajapa
    yprajapa Newbie
    I own Thinkpad T21 and I am having same problem. When I power it up the cpu fan runs for first ~10 sec and then turns off which causes the CPU to overheat quickly, which results in sudden reboot or hang. I baught another (thinking that fan is bad), the other fan is also giving same behaviour, I guess it is motherboard....anybody has any other idea?
  9. eddy
    eddy Newbie
    no chance the systemboard is defekt
    http://www-1.ibm.com/support/docview.wss?uid=psg1MIGR-4K2MCU
    [V]
  10. markymarc
    markymarc Newbie
    hey guys,
    to be honest with you, i think it is a serial failure of the mainboard, ibm knows about it and dont want to bother... personally, i will contact them and try to work it out with them, but i dont have big expectations that i will be successful. i will keep you updated. i am wondering how many people have that problem with their t20...
    marc
