System start up - should I remove ALCMTR? (Aspire 5672)
Discussion in 'Acer' started by Rob500, Sep 17, 2006.
  1. Rob500
    Rob500 Notebook Guru
    I've been looking up all the things that run at startup on my Acer Aspire 5672, using msconfig. One of the startup items is called ALCMTR. On looking this up on lots of web sites I'm getting very confusing advice! Apparently it is an application from Realtek but some sites say it is evil spyware and should be removed immediately while others say it is harmless and should not be stopped from running unless it causes errors.
    Can anyone advise on the truth of all these claims?
    If it is reporting back to Realtek as some people claim then what is it reporting?
  2. bugmenot9
    bugmenot9 Notebook Consultant
    i have it running on my computer and it causes no problems for me. but i will try getting rid of it then rebooting and let you know if i have any problems.
  3. Rob500
    Thanks, I'd be interested in the results.
    I'd be even more interested if anyone knows what information it is supposed to be sending back to realtek - if it is then it is strange that it is not being picked up by my firewall.
    If you try searching in google for ALCMTR you get lots of sites with, as I said before some very conflicting advice.
  4. bugmenot9
    there are no problems sthat i can see after telling it not to start at startup.
  5. JohnnyT
    JohnnyT Notebook Guru
    That is part of the realtek software for your soundcard, it does not need to run at startup unless you like their bloaty software.
  6. Rob500
    But is there any alternative to the Realtek software if I want to use the inbuilt microphone and speakers, etc?
    I'd like to know what ALCMTR is doing before I take it away - it might not matter now if I'm not using whatever it is for but could I need it in future?
  7. JohnnyT
    The realtek software is pretty much bloatware, you do not need it to run at startup in order for your sound, mic , etc. to work. It made me kinda mad to see I couldnt install the soun drivers without the software, but oh well. If you want to adjust settings you can either use windows sound settings. Or you can make a shortcut to the realtek program and only use it when you need it, thats what I do.
  8. forgotmyname
    forgotmyname Notebook Guru
    what are all the things we can uncheck from startup?
  9. sionyboy
    sionyboy Notebook Evangelist
    Different things work for different people. Best bet is to go through your MSConfig, make a list of all the things that run on startup and then google each one (ie, type in "qttask.exe") and see if its safe to remove, or if its something you personally would use.
    For reference, here are some of the things I have removed from startup
    ALCMTR
    Monitor
    hkmcd
    igfxpers
    igfxtray
    IMJPMIG
    Alaunch
    ImScInst
    NeroCheck
    TINTSETP (x2)
    qttask
    RTHDCPL
    SkyTel
    jusched
    Adobe Reader Speed Launch
    Microsoft Office
    Course, this is what works for me. Some stuff you may well want to keep
  10. xenoasd
    xenoasd Notebook Enthusiast
    where do u find the msconfig?
