system preparation tool
Discussion in 'Asus' started by wawawa, May 25, 2006.
  1. wawawa
    wawawa Notebook Consultant
    I reinstalled Window XP to my W3V recently using the recovery discs provided.
    After the installation, there is a system prepartion tool pops up every time I restart my computer. Does anyone know how to get rip of this tool or somehow make it so that it doesn't pop up at start up anymore?
    thanks
  2. SRD
    SRD Notebook Virtuoso
    Do you mean the Dos window thing. if so you have to let it run takes like 20 minutes.
  3. dnnout
    dnnout Newbie
    usually you just click reseal and it will restart the computer come back with the welcome to windows screen after that it should be fine. at least thats what i had to do with a sony notebook
  4. SRD
    Oh wait i know what your talking about now. I got it caught in an endless loop once on my w2v. I just dont remember what i did to solve it sorry.
  5. wawawa
    Thanks. After a few tries, I got it to work. Like you said, click on reseal, but need to make sure you check the box where it says don't create the SDI (or something like that). Problem solved.
    But now I have another problem...
    When I try to activate Window (the 30 days reminder thing), where you have to enter your product ID on the bottom of your laptop, it kept saying my product ID is invalid...wtf...
  6. SRD
    Its ok choose register or activate by telephone. Call MS they will give you an activation code by phone if you have trouble.
