Synaptics palm check please help
Discussion in 'Gaming (Software and Graphics Cards)' started by IsaacJan, Nov 7, 2017.
  1. IsaacJan
    IsaacJan Notebook Enthusiast
    I want to buy the Clevo p650HS-G laptop, but their tech support says that the laptop has palm checking that cannot be turned off. I.e when a key is pressed the touchpad disables for a moment. I really need to know if that can be turned off. If anyone can help me, I'd really appreciate it. They use Synaptics touchpad drivers.
  2. Vasudev
    Go to settings > Devices > Touchpad
    Change sensitivity to most sensitive and scroll down if there are any options or check right side pane for Advanced Settings.
