Surface Book 2 (13" and 15", GTX 1050/1060) announced
Discussion in 'Microsoft' started by iMbaQ, Oct 17, 2017.
  1. BeastsForever.TheDragon
    BeastsForever.TheDragon Notebook Evangelist
    The 7700hq will definenitely outperform the 8550u IMO.
    skyFox90 and Vasudev like this.
  2. skyFox90
    skyFox90 Notebook Consultant
    Agree
  3. phila_delphia
    phila_delphia Notebook Consultant
    Thx! I`ll give it a try when I install the game next time.
    Think so too! Still in games that demand high single core CPU clock the 8650u does quite well. I had some issues with Borderlands 2 on my 6700hq in CPU limited areas which I did not notice on my Surface Book 2. The performance in Grim Dawm is also very nice.
    Best regards
    phila
    P.S.: Has anyone tried to undervolt the GTX 1060 in their SB2 15"? I´d be curious to hear wo many watts this will save you...
    Vasudev likes this.
  4. Vasudev
    Vasudev Notebook Prophet
    Mostly it will be locked. You can try it using MSI AB and see if it works. Don't forget to save profile after undervolting.
    phila_delphia likes this.
  5. phila_delphia
    Yes, thank you! I got the 1050 in my SB2 undervolted via Afterburner. It works very well. Still, I`d be interested in expreiences concearning the 1060.
    Best regards
    phila
    Vasudev likes this.
  6. Vasudev
    Better ask @Mobius 1
  7. Mobius 1
    Mobius 1 nͫiͤcͫeͤ
    I only had the 1st gen surfacebook without the dGPU :|
    phila_delphia and Vasudev like this.
  8. Vasudev
    You have undervolted several Pascal notebook GPUs, right?
  9. phila_delphia
    Undervolting might not the very exact term, but yes: Afterburner (ctrl+f) allows to set the relation between "mV" and "mhz" (nvidia Pascal) and thus allows to run the craphics card with a lower mV/mhz-ratio. For my SB2 got two settings:
    Power saving -> with the base voltage of 800mv I achive a fixed 1278mhz
    Performance -> with a voltage of 925 mv I achive a fixed 1798mhz (about 100mv less than the card would draw at stock clocks)
    Taking this into regard, I think the SB2 15 inch 1060 draining issue, could be somewhat diminished by undervolting the GPU.
    Best regards
    phila
    Vasudev likes this.
  10. Vasudev
    Use a bigger AC adapter like 180W.
    Use nvidia inspector to turn on battery boost that will reduce the chance of pulling additional power from battery by limiting FPS to 30.
