Superb Battery saving trick for your Android phone!
Discussion in 'Smartphones and Tablets' started by Ultra Male, Sep 20, 2017.
  1. Ultra Male
    Ultra Male Super Tweaker
    I did this on my Galaxy S8 and it's like I bought a new phone, standby time is now insane the battery barely drops now...
    1) Enable Developer Mode (keep tapping on Software Info / Build Number 7 times until it's enabled)
    2) Go into developer options which will now appear at the bottom of the settings menu
    3) Scroll down all the way to the end and click on Inactive Apps
    4) You will see many apps showing the status Active, just tap on it once to set it to inactive!
    That's it, this will not disable that app or anything, all we are doing here is not allowing them to run in the background when you don't want them to, they'd still work if you manually launch them. I was shocked to see how many apps were running in the background.
    Obviously, only disable the apps that you don't really need to run in the background. Personally, I just kept Gmail, Whatsapp, Google Maps, etc. active, the rest are all inactive.
    I've charged my phone to 100% like 2 hours ago and now I am looking at it, it's still at 98%! This is insane! Previously, it would be like 85% by now!
  2. Mitlov
    Mitlov Shiny
    Power companies hate him
    jaug1337 and bloodhawk like this.
  3. Vasudev
    Vasudev Notebook Prophet
    Does this work on S7? I believe Samsung Members app does a similar thing.
    One thing that bugs me is, I always set background apps to max of 3, but those settings aren't persistent i.e. after a reboot it goes to default OS recommended values
  4. daysarelost
    daysarelost Newbie
    I think this really depends on your apps using. I'm a bit of a minimalist but that is what i get without using this setting. 2 hours 2% drain.
    Vasudev likes this.
  5. Mitlov
    Mitlov Shiny
    It does work on my S7 Edge in the sense that the option to inactivate each app is there in developer tools. But Samsung's device maintenance app does this automatically (at least by default), and I found that most of my apps were already set to inactive.
    Maleko48 and Vasudev like this.
  6. Tinderbox (UK)
    Tinderbox (UK) Sir Pumpkin Longshanks
    On Android 6 and under in developer mode you can select how many active apps to keep in memory, select background process limit, I set mine to zero to see what happens.
    John.
    Vasudev likes this.
  7. Ultra Male
    you can also do that on the S8
    Vasudev likes this.
  8. Ultra Male
    all
    Vasudev likes this.
  9. JRE84
    JRE84 Notebook Evangelist
    on antutu battery i was getting 8800 without this tweak....with this tweak i got 11943
    this should be stickied because this can save people 3hours on their phone and actually works
    i have tried everything via youtube tuts to get the best battery life and this is by far the best tweak
    Ultra Male likes this.
  10. Ultra Male
    Just did this tweak on my BlackBerry KeyOne
    jaug1337 and Vasudev like this.
