Suggest a decent cooling pad for Dell XPS 15
Discussion in 'Accessories' started by mikolajek, Mar 8, 2018.
  1. mikolajek
    mikolajek Notebook Enthusiast
    Since I've attached the TB16 to my XPS 9550, the trio of CPU + GPU + TB chip is producing enough heat to have my fans making me mad (and I'm not a gamer!).
    Thus I'm looking for some cooling solution to fight it. The issue I see is that XPS' air vents are located at the bottom, so any classical pad that blows the air into laptop bottom, won't work here and may actually do more harm than good.
    Most likely some sort of air sucking solution would fit better, but I can't find any...
  2. don_svetlio
    You're pretty much wrong on all fronts
    The air vents being on the bottom means a traditional cooling pad is the best solution, though that will likely cause more noise since you are just adding fans. It will likely decrease thermals by about 5-6*C
    An air-siphoning solution is not only impossible to use due to the position of the exhaust near the hinge but also those solutions do not work.
    The best solution is a cooling mod like this one: https://www.ultrabookreview.com/14875-fix-throttling-xps-15/
  3. mikolajek
    Hi there, I've already undervolted my XPS and also changed the cooling mode into passive. Still, it's pretty loud I'm afraid... That's why I'm looking for some supporting solution.
  4. don_svetlio
    There's no real way to decrease noise - a cooling pad always results in an increase in noise since you are adding 1-3 more fans. The pads are intended to reduce thermals at the cost of more noise.
    mikolajek likes this.
  5. mikolajek
    Yeah, I've read multiple times that for XPS devices noise is a real problem, as they are not masters of air circulation (which is clear given their construction).
    I was hoping some hot air sucking may actually improve cooling, but...
  6. don_svetlio
    The devices that are placed on the vents to siphon air from the heatsink are
    1 - very noisy due to the radial fan
    2 - useless because they don't really add any airflow to the equation
  7. TheReciever
    TheReciever D! For Dragon!
    Only thing I see thats worth it is a Coolmaster U2/U3 with 2-3x 120mm fans powered externally
    Mr. Fox and Papusan like this.
  8. mikolajek
    Well for me it looks that any quiet cooler that allows for discretional arranging its fans, will do the job. That way I could blow the air into hot places and not to interfere with the laptop coolers blowing the air out of the case.
    On the other hand a few Reddit users have suggested Zalman NC 3500, which I like very much. The only (and major) disadvantage is that I can't hunt it in literally any Europen web store. And in fact CoolerMaster U3 is listed at their site as discontinued as well... :(
  9. Papusan
    Tested Zalman NC 3500 a few years ago. Save your money. Go for the CoolerMaster U2/3. And replace the original fans with 12v fans. U2 is probably big enough. Or just skip the idea and rather use a couple of Coke bottle caps.
    Mr. Fox and Ashtrix like this.
  10. boricuafly
    boricuafly Notebook Consultant
    Cooler Master NotePal U3 PLUS it has 3 movable fans. Well worth it
    Papusan likes this.
