Successful MXM GPU Upgraded Laptops
Discussion in 'Hardware Components and Aftermarket Upgrades' started by sicily428, May 21, 2017.
  1. Barbadadost
    Barbadadost Notebook Enthusiast
    Is this works with Full HD non DC screen?
    Anny guide?
    What wirk and mods need to be done?
    Thanks...
  2. mirage_bg
    mirage_bg Notebook Deity
    Highly doubtfully.
    Pascal gpus need eDP panel to work properly, can‘t see a reason why Turing should be different...
  3. Mastermind5200
    It could work in Optimus enabled mode.
  4. Branzy1987
    Branzy1987 Notebook Evangelist
    Hi.
    I have a clevo p770z
    With i7 4790k
    And
    Gtx 970m
    What is the maximum gpu I can put?
    Thank you
  5. skandal
    skandal Notebook Evangelist
    A 980M, or maybe a 980 MXM. But the 980M for sure you can upgrade to.
    Branzy1987 likes this.
  6. Branzy1987
    For 980m I would not upgrade it, but I was wandering if I could go to 1070?
  7. Reciever
    Reciever D! For Dragon!
    SHOULD be able to, but if you use the MSI 1070 will need to do some modifications.
    Ive only seen a few screenshots from a chinese website that more or less paints the picture that it works. Havent been able to confirm it personally yet.
  8. MrMogwai
    MrMogwai Notebook Evangelist
    Would it be able to get my own update of AW M17xR5/17R1 with P4000 in OP? Also planning a further expansion with P5200 as soon as I get some disposable income.
  9. Khenglish
    Khenglish Notebook Deity
    The ZM series is LVDS internal display only. A 1070 would not be able to drive your internal display.
    UPDATE:
    Ignore the above. I was thinking of the SM series, just before the ZM.
  10. Reciever
    ZM? As in p7x0zm? Mine is 30 pin 2 way eDP.
    Unless your referring to another model?
