Subwoofer on P150HM not working?
Discussion in 'Sager and Clevo' started by belegdol, May 10, 2011.
  1. belegdol
    belegdol Notebook Geek
    Hi,
    I have recently received my shiny new P150HM from MySN. The problem is that it seems that the subwoofer is not being detected at all (Windows nor Linux), and sound tests for subwoofer do not play any sound at all. Is it possible that it is disconected, and if so, how easy would be to fix it? I would rather not ship it all the way back to Germany (I am in Switzerland) if this is something trivial. Thanks in advance.
  2. TheGreatAnonymous
    TheGreatAnonymous Notebook Consultant
    Try hitting the Fn+5 key to enable it. Someone here posted about this not too long ago, and apparently it's in the manual as well. Imagine my surprise when I found out about it, because it makes a huge difference in sound.
  3. Eivind
    Eivind Notebook Evangelist
    Fn+5 only works with the P170HM. Not the 150/151.
    About the subwoofer. I dont know if it is working or not. It sure doesnt sound like it.
  4. belegdol
    As Elvind expected, it didn't help. According to the manual that key combo is only for p170hm anyway.
  5. TheGreatAnonymous
    Oh wow, didn't know that. Sucks to have to send it back for something so minor.
  6. mountainlifter_k
    mountainlifter_k Notebook Consultant
    Do you not feel the vibrations when you place your palm on the grill under the chassis??
    What do you mean when you say that windows is not detecting the subwoofer?
  7. Harleyquin07
    Harleyquin07 エミヤ
    Congratulations for not reading the original post, when the OP says sound tests using the inbuilt windows software or the like don't have any sound emitting from the subwoofer when it's supposed to, I would think vibrations are out of the question.
    Back on topic: I assume volume controls and equalization haven't accidentally cancelled out the subwoofer output? If not, it may be a hardware problem unless it was working fine before.
  8. mountainlifter_k
    I did read the OPost. Yes, I was unfortunately asking the obvious. But your sarcasm didn't help him either, Joker's Assistant! :D
    Back on topic: In device manager, the speaker and the sub-woofer are never listed, right?. Just the sound driver or some such thing.
    (I don't have the laptop with me now so I don't know exactly what is listed under audio in device manager)
    So, when the OP says he cant detect it, I wonder what he means.
  9. Harleyquin07
    Harleyquin07 エミヤ
    Unlike someone posting above me, I did try and help by asking whether or not volume controls and equalization settings were muting the subwoofer by accident, unlikely as it is. Even in Windows Vista, there's a simple sound test function where you can get sound to come out from specific speakers using the test function.
    No, you don't see if speakers are connected to the Windows Operating System via Device Manager. It only lists which SOUND CARD is connected to the system.
    Regardless of my "sarcasm" above, I recommend the OP crank up bass settings and volume as much as possible before testing the individual speakers again. If nothing is heard from the subwoofer using these test conditions, then it's likely a hardware problem. I'm no expert but internal wiring isn't as easy as to fix like a RAM upgrade or the like.
  10. mountainlifter_k
    In the Realtek Audio manager, you can test only the left and right speakers. Not the subwoofer; though i dont have the laptop with me now, I remember this much.
    So, again, I think the important issue is: what does he mean when he says it cant be detected?? (As you said, only the Audio Driver/Card is listed in Device Manager; so, he is not talking about that.)
    Is there some software he is using to detect and test the speaker/sub-woofer? If so, what is it? We could download and do the test on our machines to compare. Lets just wait for his reply.
