Sub $1500 gaming-capable thin and light
Discussion in 'What Notebook Should I Buy?' started by jauffrey, Feb 13, 2018.
  1. jauffrey
    jauffrey Notebook Enthusiast
    Hello,
    I am the proud owned of an MSI Dominator Pro (7700HQ, 1060 6GB, 17.3" 120hz) and while I love the laptop and it is super powerful, it's just too big for travel. I travel very often and want something thin and light-ish to bring with me.
    I'm looking for a thin and light-ish 15.6" laptop. An 8550u paired with an mx150 or 1050 would work great, I'm sure, but my biggest fear is thermal throttling. I was all set to pull the trigger on an HP Spectre 15 x360 (8550u, mx150, 15.6") but have read mixed reports of thermal and coil whine issues which has scared me off for now.
    This is a secondary laptop, and would need either user-upgrade-able SSD (m.2 or 2.5", or both) or a big enough (512GB+) on-board SSD. 8GB of RAM would be fine, but bonus points for 16GB at this price point. I want something light (sub-5 pounds, but the lighter the better) but it has to be 15.6", because my eyesight doesn't like 13.3" laptops. Also, I'm looking for a dedicated GPU and few (any?) 13.3" systems offer this. For the screen, I'm happy with 1080p or higher, but prefer a touch screen or glossy non-touch screen. 2-in-1s with pen support are the ideal, but not required.
    Basically, I want something portable that won't over-heat but can still play some Ark, Fortnite, *maybe* PUBG and Age of Empires/Starcraft 2 once in a while. I'm an experienced user and not afraid to re-paste. I tried an XPS 15 (7300HQ, 1050, 16GB, 4k) and it was a sexy machine but a little buggy and got pretty hot - surprising, I know - so I returned it. Also, the 7300HQ may be a bit slow for such a high TDP CPU, and thus my focus shifts to the 8550u (or a thin and light with a 7700HQ that doesn't overheat!)
    Any help is greatly appreciated!
    General Questions
    1) What is your budget?
    Up to $1,500 USD
    c. Thin and Light; 15" - 16" screen
    US
    a. Like: indifferent
    b. Dislike: Asus (bad durability-related experiences)
    No
    Anything and everything, from web browsing, heavy MS Office use (not 365) to light gaming
    Portability is the name of the game
    Yes, all kinds, limited only by the GPU
    5+
    Would prefer retail availability, but online is fine
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, Chrome OS, etc.
    Windows 10
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    1080p and up
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Glossy - hate matte
    Build Quality and Design
    No
    ASAP
    3-5 years
    Notebook Components
    SSD, 256GB+
    No
  2. Vistar Shook
    Vistar Shook Notebook Deity
    You can check out the Lenovo Yoga 720 (15)....it does fit most of your requirements....however I have no idea about thermals and such....hard to avoid when going for thin and light and a dGPU.
    jauffrey likes this.
  3. LordDavon
    LordDavon Notebook Evangelist
    I second the Lenovo Yoga 720. It goes on sale often, so wait for a good sale. Bestbuy had it for $1199 with the 512GB SSD a couple weeks back, so it should head back down to that price in a week or two. I played with the display model and it was pretty impressive. It is also under 5 lbs, so light enough for travel.
    I ended up getting the Surface Book 2 instead, but was able to increase my budget. Under $1500, the Lenovo is one of the best choices.
    Vistar Shook and jauffrey like this.
  4. jauffrey
    Thank you both - I had no idea they started making the Yoga with such beefy specs. I've actually been messing with buying a laptop (returning XPs 15s, etc) for the past 6 weeks, so I think I'll make my purchase this week; Best Buy has a great price match policy in the event it goes on sale in the next month or whatever.
    Vistar Shook likes this.
