Studio 1535/1537 Fingerprint Scanner
Discussion in 'Dell' started by mijlfc, Aug 15, 2009.
  1. mijlfc
    mijlfc Newbie
    Hi,
    Firstly im not actually sure which Studio laptop i have, on the bottom is sais it is 1537. But when i go on my computer and right click on properties to look at the system info it sais the model is 1535??
    Also i have a built in fingerprint scanner but not sure what to download etc.. ive downloaded the driver from the dell website, and i dont have the digialpersona software. so where do i go from here?
    Thanks
  2. Mayhew132
    Mayhew132 Notebook Enthusiast
    Hi there,
    The digitalpersona software comes included on a CD-ROM with your system. If you have mislaid your cd either contact dell to send you a replacement cd or I could send you the installation archive in an email.
    Thanks
    Guy
  3. mijlfc
    mijlfc Newbie
    Yea if you could send the installation archive in an email thatll be grand.
  4. mijlfc
    mijlfc Newbie
    And also im currently on vista home premium on 32bit and want to upgrade to 64 but how do i this?
  5. Mayhew132
    Hi there,
    If you could send me your email address in a personal message i'll email the archive. As for x64 vista, upgrades arent supported, it would need to be a clean install.
    It's worth noting however, that the COA and serial key for you vista 32-bit will be valid for an x64 installation, so all you need to do is get your hands on the installation media....
    Cheers
    Guy
  6. Mastershroom
    Mastershroom wat
    If you call Dell, they should be able to provide you with an installation disk for Vista 64-bit.
