Stable and resilient laptop for high load tasks
Discussion in 'What Notebook Should I Buy?' started by Suncatcher, Nov 26, 2021.
  1. Suncatcher
    Suncatcher Notebook Enthusiast
    1) What is your budget?
    1.5K USD
    c. Thin and Light; 13" - 14" screen
    d. Mainstream; 15" - 16" screen
    3) Which country will you buying this notebook?
    Worldwide. I like Walmart, Amazon, Bestbuy but also it can be on-site vendor outlets (HP, Dell, Acer)
    a. Like:
    b. Dislike:
    No special preference, except I don't trust newcomers in this business: Honor, Xiaomi, etc.
    No.
    Video editing, mastering, VM (virtual machines)
    Mainly on desk
    8) Will you be playing games on your notebook? (If so, please state which games or types of games?)
    No
    2-3
    Online is ok
    11) What OS do you prefer? Windows, Mac OS, Linux, Chrome OS, etc.
    Doesn't matter
    12) What screen resolution(s) would you prefer? (See further below for explanations.)
    Doesn't matter
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (See further below for explanations.)
    Matte is better but it's not a really critical decision factor
    No
    15) How much hard drive space do you need?
    Doesn't matter, because I have a M.2 stick to upgrade
    16) When are you buying this laptop?
    Now
    17) How long do you expect to use this laptop?
    3 years
    18) How long could you afford to do without your laptop if it were to fail?
    2 weeks
    19) Would you be willing to pay significantly extra for on-site warranty, or would it be acceptable to you to have to ship the laptop to the vendor for repair with perhaps a week or more outage?
    No
    20) Should it be upgradable?
    Yes! I don't accept rigs with the soldered memory or SSD. I want something possible to upgrade.
    Long story short, I'm a developer, but I do not do work at home and this laptop I am buying is for home activities. But I do a little video composing/editing at home just for fun, so the laptop should be performant and resilient, on my current one HP Probook 430 G5 I cannot properly render in Adobe After Effects even with 32Gb of memory.
    I want to highlight am not choosing the laptop solely for Adobe AE, I also occasionally (!) run virtual machines and other tasks, but AE is a good example how heavy tasks can be a stress-test for laptop.
    I know my budget is a bit tight for video mastering, but maybe you can suggest couple of decent options. Also I have spare RAM and SSD to replace, so I don't really care what comes out of the box, only the CPU and chipset matters, it should be Core i7 or higher-level Core i5 of latest generations (10+).
    On my workplace I changed 3 different laptops this year and the most I liked was Lenovo ThinkPad P15v, however it exceeds my budget. For other brands I have no special preference nor distrust.
  2. ZaZ
    There's a few of these floating around the Lenovo Outlet under your budget. I'd lean towards this one, for the very good 4k 600 nit LCD.
    Rokobo and Suncatcher like this.
  3. Suncatcher
    thanks. do I have any other alternatives?
  4. ZaZ
    If the ThinkPad P15v is model of what you want, it would seem you're looking for a workstation. Lenovo along with Dell and HP offer them, but your budget is going to be an obstacle if you want new. You could go use, but that presents its own set of issues.. If you want to go more on the consumer side you might be able to find a Dell XPS 15 with dedicated GPU under budget. The XPS is a well made notebook with great screen. If you want an inexpensive notebook that packs a punch, the Acer Swift 3 with Ryzen CPU might be worth a look and comes in half your budget, though you'll get an integrated GPU. There's so many choices these days you can go in any direction. If you want a workstation I believe the ThinkPad I linked above is good choice.
    If you buy directly from the manufacturer, it's most likely a return that'll look new and come with at least a year of warranty. Plus, you get a nice discount over new. Given your somewhat limited, this seems like the best path to a notebook you like with a warranty.
  5. N2ishun
    N2ishun Notebook Evangelist
  6. Rokobo
    Rokobo Notebook Enthusiast
    I would grab that Thinkpad P above and run. That one is robust
  7. Suncatcher
    actually I was considering this model, but still unsure. How this gaming G series with Ryzen 7 behaves in video tasks like rendering and applying effects? did you use it personally? how is the screen?
  8. Suncatcher
    thanks for your advice, I did look into XPS side before but now chosen my fav brand - MSI, and couple of favorite models: MSI Modern A11M, MSI Summit B15 and E15, MSI Prestige A11M. MSI gaming laptops are also very cool, but the lack of Thunderbolt 4 and PD is a dealbreaker for me.
    Maybe you know MSI series, what actual model you can suggest for my aims?
  9. win32asmguy
    This GS66 may work for you:
    https://www.bestbuy.com/site/msi-gs...ssd-16gb-memory-black/6464557.p?skuId=6464557
    I do believe all GS66 and GS76 have TB4 ports supporting power delivery. Luckily this model also has easy to upgrade SSD and RAM slots so upgrades can be done.
    Suncatcher and saturnotaku like this.
