SSD heat! Simply solution !!
Discussion in 'Razer' started by sarou, Jul 1, 2018.
  1. sarou
    sarou Notebook Consultant
    Which parameters for the test ?
  2. sarou
    I just ran 5 tests consecutive with ATTO. Default options : 56c Max
  3. sarou
  4. rinneh
    rinneh Notebook Prophet
    Becareful though, now you made contact between your SSD and backplate, the backplate flexes a bit so if you press the backplate inwards you are pushing extra stress onto the drive connector which isnt really ideal.... The lifespan isnt too great for these connectors to begin with.
  5. sarou
    The pads touch just a little bit the backplate. With very ligh pressure. Just a simply contact to transfer thermal.
    No pressure on ssd connector.
