Spilled water on keyboard = some letters doesn´t work :/
Discussion in 'Hardware Components and Aftermarket Upgrades' started by victorgm, Oct 10, 2017.
Tags:
  1. victorgm
    victorgm Notebook Enthusiast
    Hello everyone!
    I´m the owner of a MSI GS60 2PC, and yesterday while I was working (as I use it for my architecture job), I spilled the half of a glass of water on the keyboard....I tried to react quickly and clean and dry it with paper, but I was stupid and left it on for 15mins more, as I thought that it was not too much water (now I´ve read I should have shutted it down inmediately). After it I dried it with a hair dryer (minimum heat) and left it all night facing down on the sofa.
    Right now, I have tried to use it (for working), and sadly there´re some letters that are not working on the middle-left side....and the warranty expired some months ago...on the other hand, the laptop seems to work fine as always.
    I´ve opened my laptop like 3 times to change the SSD/RAM/M.2, so I know how to dissamble the keyboard. What I don´t know if how to repair/clean/dry the keyboard if I dissamble it...or how to detect if the water has also affected the motherboard or other circuits...could you please help me?
    Another option would be to buy a replacement, but it cost +150€ on ebay, so I would prefer to try first myself.
    Many thanks! i´ll be waiting for your tips!
    Victor
  2. Starlight5
    Starlight5 So what if I'm crazy? The best people are.
    @victorgm remove the keyboard right away, stop using the laptop with it. Pour a lot of distilled water (available in auto parts shops, gas stations etc) on the keyboard. Let it dry for a week or so in a warm place, use the laptop with external keyboard while it's drying up. You'll likely end up ordering a replacement keyboard (here's non-backlit for $45 which might be compatible, check it out), but worth a try.
    victorgm likes this.
  3. victorgm
    Hi Starlight5, many thanks for your answer!
    I have tried to follow your advice, just to discover that I had to disassemble everything, and finally I discovered that the keyboard of my laptop MSI GS60 2PC is somehow glued to a metal plate...so it's almost impossible to remove just the keyboard alone...and if I want to replace it, I should buy the keyboard+the frame "C" together....a nice sh*t...because that costs +190€...
    Right now the metallic plate looks like this:
    https://imgur.com/a/sDjZo
    Im writting now from an usb keyboard, as some keys are still not working...any ideas?
    Many thanks again :)
    Starlight5 likes this.
  4. Starlight5
    @victorgm well, your best bet is to give it a week to recover and hope for the best. Good thing it was just water, not wine or cognac.
  5. victorgm
    Many thanks Starlight5 again :)
    I will try that, and meanwhile I will continue using an usb keyboard...
    Just one last question: If I continue using the laptop without touching the keyboard, would it be possible it to recover? or should I let it turned off for some days? because i need it for working... :/
    Many thanks!
  6. Starlight5
    @victorgm give it a day or two if you can, and/or use the fan again. You can try using it as soon as you're sure it dried up. I had a (desktop) Mac keyboard with the same problem, that fully recovered eventually.
  7. KY_BULLET
    KY_BULLET Notebook Evangelist
    You're probably going to have to buy a new keyboard. I would definitely take off your keyboard and make sure no trapped moisture makes it to the top of your mobo. If that happens, well you know what happens next.
  8. aaronne
    aaronne Notebook Evangelist
    I resurrected mine mobo (water damage trough keyboard when in power recharge and in use) by spilling on it many etanol alcohol (isopropanol) at 99,5% purity, and brushing the oxided part by a tootrbush
